Results 1 to 7 of 7
Thread: Speed Up Satelite Signal Fix for GPS on Android
    Nasir's Avatar
    Fire
    Gionee GN708W Quad Core
    Android 4.1.2 Root
    Method 1 =
    There are a lot of posts and information regarding the GPS issue that some are experiencing. I am starting (yet) another post in the interest of compiling and maintaining information regarding that information in one location. As users/devs find out information I will update this post so everyone doesn't have to go looking everywhere for the information. I am hoping that the Moderator will sticky this post.
    Some users are experiencing very long lock times for their GPS. Everyone, after reading A LOT of posts/threads it seems to be the consensus that this is a software/settings issue - NOT, a hardware issue. However, results from tweaking the following settings are very mixed. Most seem to get great results by tweaking the following settings while stationary - but, moving is a whole different ball game. I use the below settings and have great results while stationary. However, my G1 blows the Captivate completely out of the water!!! My G1 gave 3-10m accuracy while driving. This device can barely keep me on the correct highway and always seem lagging behind my current location. The G1 was spot on no matter what. What hasn't been determined is if these issues are hardware or software. For whatever my opinion is worth - I think it is a firmware/software issue. Here are some things to try.
    Here is the info:
    To get to your GPS settings open you dialer and dial the following number. This will not call anyone - it is a code shortcut to the settings:
    *#*#1472365#*#*
    Once entered you will observe a screen that has five buttons:
    Get Position Test
    Application Settings
    SUPL/CP Settings
    Test Application
    Delete GPS Data
    We will be interested in three of these initial buttons.
    Get Position Test: This will be what one uses to test the results of your changes.
    Application Settings: Exactly what it says.
    SUPL/CP Settings: settings that determine specific data connectivity with the satellites.
    In Application Settings the following are some that you might consider adjusting:
    Operation Mode - Standalone, MS Based, MS assisted, Network Provider
    Accuracy - defaults to 50. Don't set it below 10 (and only use increments of 10's)
    SkyHook - not sure what it does. But, someone on a thread mentioned it and it DOES effect satellite lock times.
    In SUPL/CP Settings one we'll be interested in the following:
    Server FQDN Type
    Server
    Server Port
    The following are the options provided on other threads:
    Original/Stock Settings:
    SUPL/CP Settings/SErver FQDN Type/Custom Config
    Application settings/Operation Mode/Standalone
    SUPL/CP Settings/Server/www.spirent-lcs.com
    SUPL/CP Settings/Port/7275
    Second suggested setup (from other posts and claimed to have great results):
    Application settings/Operation Mode/MS Based
    SUPL/CP Settings/Server/supl.google.com
    SUPL/CP Settings/Port/7276
    Other settings that I have played with:
    Application settings/SkyHook/On (and Off)
    SUPL/CP Settings/SErver FQDN Type/Auto Config (and Custom Config)
    You can play around with these to see what gives you the best results. If your GPS doesn't work better with whatever changes you made - than you can always put it back to the orginal settings above.
    However, it has been recommended and I concur (for whatever that is worth) that you NEED TO SET THE FOLLOWING BEFORE YOU START PLAYING AROUND: Settings/Location and security/uncheck (turn off) "Use Wireless Networks). Most likely this won't really effect anything while your testing within the GPS settings - however, this will effect your results if you test using Google Maps, etc.
    Now, having duly noted all of the above and having played around with the settings for several hours I found the best results FOR MY DEVICE IN MY AREA AT ONE LOCATION was the following:
    Note: I adjusted these settings from earlier as the earlier settings proved to be very accurate when stationary - but, very inaccurate while moving. The latest settings I'm using are below. Also, look to the bottom of this post regarding changing your gps configuration file. That also helped A LOT. The bottom section of information is from the Official websites that run the time servers(effects GPS performance).
    Application Settings/Operation Mode/MS Based
    Application Settings/Operation Mode/SkyHook/ON (VERY IMPORTANT)
    SUPL/CP Settings/Server FQDN Type/Custom Config
    SUPL/CP Settings/Server Port/7276
    SUPL/CP Settings/SUPL Secure Socket/Off
    Turning "SkyHook" ON assisted in faster locks with ALL of my tested settings when stationary!
    My test results with the above would lock on up to three satellites in under four seconds and between 7 and 10 by eight seconds. Google Maps would locate me in about 6-8 seconds.
    Using "Get Position Test" the settings in the three lines above consistently gave the not only the fastest locks and the most locks - but, also STRONGER SIGNALS!
    I used at least seven different combinations of the above settings and some of them were just as quick - but, not as strong. Most of them were slower.
    If anyone has better information to add then please PM me and I will add it to this top post.
    LASTLY, I will make some guesses as to what some of the other settings do as I have heard different information:
    Session Type: Tracking or Singleshot - obvious (use Tracking)
    Start Mode: Hot or Cold Start - someone posted on a thread that Hot uses data from your last read to get started. Cold start will start all over. So, Cold start SHOULD increase the time for you to get a lock unless you went left the area to an area that had different satellite to look up.
    Test Application:
    Performance Test: worked for me - but, I found the test above to work faster and give me quicker results for what I wanted.
    Hardware Test/Sensitivity Test: Pretty cool - went on forever and I stopped it.
    CNO Test: Seemed to test the average satellite signal strength.
    Antenna Test: Never worked for me and I received errors.
    H/W Test Settings: Settings for the above tests - I didn't mess with them.
    NOTE: WANT TO SEE HOW ACCURATE YOUR ACCELEROMETER/COMPASS/ORIENTATION settings are? Check this out:
    Test Application/Show Sensor Data - there is no way to calibrate it here... But, you can see just how sensitive your instruments are!!
    Delete GPS Data - I didn't select this button and I don't recommend anyone else doing so either unless someone from Samsung tells us what it does. LOL!
    FINALLY: Keep in mind that if you are seeing GPS lock times that are in the 3-8 second range (which was what I was getting) this WILL NOT be how long it takes for Google Maps to get the GPS data! Expect 8-15 seconds or a little longer (but, under 30 seconds) for Google Maps to pick up your location. Although the GPS sensors might pick up the satellites - you still have to give the software time to evaluate the data and apply it to the software.
    Hope this helps someone out there.
    Update/Additional Information (http://androidforums.com/1194187-post197.html):
    Hot Start - The GPS receiver remembers its last calculated position and which satellites were in view, the almanac used, and the UTC Time. It then performs a reset and attempts to acquire satellites and calculate a new position based upon the previous information. This is the quickest re-acquisition of a GPS lock.
    Cold Start - The GPS receiver dumps all information and resets. It then attempts to locate satellites and then calculate a GPS lock. This takes the longest because there is no known information. The GPS receiver has to attempt to lock a satellite signal from all of the satellites, basically like polling, which takes a lot longer than knowing which satellites to look for. This re-acquisition of a GPS lock takes the longest.
    Thanks to Shadow77895 for the link to this info. I altered the settings above. Doesn't effect my results much at all.
    MSBased Operation Mode(http://www.vzwdevelopers.com/aims/pu...sp#GenQues11):
    What is MS-Based mode of operation?
    In MS-Based mode, the network provides the satellite information to the device, based on a rough estimate of where the device is located, and the device acquires the GPS signals from the satellites and calculates its location. After the initial fix, the device operates like an autonomous GPS receiver, until the satellite information must be refreshed, at which time the device goes back to the network to update the satellite information. MS-Based mode is appropriate for applications that require the device location to be updated rapidly, such as a navigation application.
    And email thread regarding using the Google settings for GPS(http://osdir.com/ml/android-platform.../msg00386.html)
    NEW INFORMATION!!!
    ALSO! Check out this page: http://www.pool.ntp.org/en/use.html:
    As pool.ntp.org will assign you timeservers from all over the world, time quality will not be ideal. You get a bit better result if you use the continental zones (For example europe, north-america, oceania or asia.pool.ntp.org), and even better time if you use the country zone (like ch.pool.ntp.org in Switzerland) - for all these zones, you can again use the 0, 1 or 2 prefixes, like 0.ch.pool.ntp.org. Note, however, that the country zone might not exist for your country, or might contain only one or two timeservers. If you know timeservers that are really close to you (measured by network distance, with traceroute or ping), time probably will be even better.
    Find your optimal pool server here: http://www.pool.ntp.org/zone/north-america
    For US the optimal server is: us.pool.ntp.org
    Reference other threads I (http://ip208-100-42-21.static.xda-de...d.php?t=731462) I recommend you do the following:
    Use Root Explorer or some other method (I use Root Explorer as it has a built in Text Editor and automatically backs up the altered file.) to go to here:
    system/etc/gps.conf
    Use the text editor to alter the gps.conf file to this (if you are in the US):
    NTP_SERVER=us.pool.ntp.org
    XTRA_SERVER_1=north-america.pool.ntp.org
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    If you are NOT in the US go to here: http://www.pool.ntp.org/en/use.html and look at the links in the center of the page to navigate to the closest pool to your geographical location and use that pool for the top server entry.
    REQUEST FOR ADDITIONAL INFORMATION:
    Many are suggesting that we do NOT leave the Secure Socket ON. How will this effect data security with our devices? I don't understand how it could hurt us... But, there must be a reason for it. If someone could let me know I would appreciate it.
    METHOD 2 =
    Guys,
    I decided to write this because a lot of us here still facing GPS issue on their device. I almost give up on my HTC Desire HD because of the GPS problem. After I find this trick, now I realized that HTC devices have one of the most brilliant GPS hardware. It always get a location lock within 5 - 15 seconds.
    This trick not only to speedup the satelite fixing. Some also found that it increase the reception (strong signal even during cloudy, light raining, and inside building's window). I am one of this case .
    Here is the tricks. It is tested on HTC desire HD, SGSII, and speculated to work on most Android device (Please note that it is in sequential order):
    Requirements:
    • Rooted Device
    • File Manager: e.g. Root Explorer
    1. Searching for NTP server information
    • At the right side of webpage, there is "Active Servers". Go in and look for the setting of your 1)region and 2)country
    • For example, one's region is Europe then you write down the NTP server for that: 0.europe.pool.ntp.org; 1.europe.pool.ntp.org; 2.europe.pool.ntp.org; 3.europe.pool.ntp.org
    • Then the servers for your country from the list down there and click the link(Example: Switzerland — ch.pool.ntp.org; 0.ch.pool.ntp.org; 1.ch.pool.ntp.org; 2.ch.pool.ntp.org; 3.ch.pool.ntp.org
    • The "Italic" words are the information you need to jot down for later use
    3. Modify the gps.conf file (Most Crucial Stage)
    • Download Modified gps.conf file from http://logfile.x10.mx/ to your device / OR As a alternative way, you can copy the codes in grey box (in first post) to a notepad, then change the extension name from .txt to .conf then copy to your phone
    • Use file manager to copy to this location: /etc/gps.conf and replace the original gps.conf
    • Open and Edit the gps.conf using rootexplorer or others file managers
    • Change the COUNTRY and REGION in following lines with the info you got from the website just now. Keep other values unchange unless you know what it is. Example of REGION such as NorthAmerica, Asia, Africa, Europe.
    • Your new gps.conf should look as below:
    NTP_SERVER=COUNTRY.pool.ntp.org
    NTP_SERVER=0.COUNTRY.pool.ntp.org
    NTP_SERVER=1.COUNTRY.pool.ntp.org
    NTP_SERVER=2.COUNTRY.pool.ntp.org
    NTP_SERVER=3.COUNTRY.pool.ntp.org
    NTP_SERVER=0.REGION.pool.ntp.org
    NTP_SERVER=1.REGION.pool.ntp.org
    NTP_SERVER=2.REGION.pool.ntp.org
    NTP_SERVER=3.REGION.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    # DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
    # 4 - Debug, 5 - Verbose
    DEBUG_LEVEL =0
    # Intermediate position report, 1=enable, 0=disable
    INTERMEDIATE_POS=0
    # Accuracy threshold for intermediate positions
    # less accurate positions are ignored, 0 for passing all positions
    ACCURACY_THRES=0
    # Report supl ref location as position, 1=enable, 0=disable
    REPORT_POSITION_USE_SUPL_REFLOC=1
    # Wiper (wifi positioning), 1=enable, 0=disable
    ENABLE_WIPER=1
    ##### AGPS server settings #####
    # FOR SUPL SUPPORT, set the following
    SUPL_HOST=supl.google.com
    SUPL_PORT=7276
    SUPL_NO_SECURE_PORT=3425
    SUPL_SECURE_PORT=7275
    SUPL_TLS_HOST=FQDN
    SUPL_TLS_CERT=/etc/SuplRootCert
    # FOR C2K PDE SUPPORT, set the following
    C2K_HOST=c2k.pde.com
    C2K_PORT=1234
    CURRENT_CARRIER=common
    DEFAULT_AGPS_ENABLE=TRUE
    DEFAULT_SSL_ENABLE=FALSE
    # TRUE for "User Plane", FALSE for "Control Plane"
    DEFAULT_USER_PLANE=TRUE
    • Make sure the permission of the file is rw-r--r--
    4. Reboot
    • Go setting, turn on your "use GPS satelites" and "Integrate Google Navigation"
    • Restart the device (normal restart)[/B]
    5. Use GPS status and Toolbox
    • Tool available in market for free, please donate so developers are encouraged for better release in the future[/B]
    • Open app> tools> manage A-GPS state>Reset
    • Open app> tools> manage A-GPS state>Download
    • Optional restart device (not compulsory)
    • Use GPS status to start fixing satelites
    • Your satelite fixing speed should VERY FAST now
    • After get a successul GPS Lock, open your GPS applications and use like normal (e.g. Copilot, Sygic, or TomTom)
    Extra Suggestion: Please make sure your GPS is enabled before your device is turnoff or restart. It won't actually use GPS unless you open map-related app or google.com.
    CAUTION!!!: DO NOT use fasterfix after this. It will overwrite all the content in gps.conf
    Credits: Thanks for JMax and Vault Killer for the gps.conf file
    WARNING: Please do backup before messing with your device
    Do it at your own risk, I cannot be held resposible for any damage or dysfunctional of your device
    Please post your feedback to let others know it works on your device model
    Please click "Thanks" if you feel this post is useful for you
    Thanks xda members for finding all tricks
    May 2010
    Australia
    Default Re: Speed Up Satelite Signal Fix for GPS on Android
    Hmmmm....code shortcut to access GPS settings doesn't do anything on my Desire HD 2.3.3. Pity. Looked interesting to try. Thanks anyway.
    Nasir's Avatar
    Fire
    Android 4.1.2 Root
    Try method 2 manually edit your gps.conf file
    Sep 2011
    mumbai
    nokia 5800
    this does nt happens in my nokia 5800
    After doing method 2 on my old x10 now gps fix takes only 5-10 sec thanks for tricks man. Also you have to turn on wifi for better gps signal
    india
    nokia 5800
    does it work on sgs i9000?
    rana's Avatar
    Oct 2009
    Bangladesh
    Xperia Z
    Android 4.2 (Rooted)
    Online
    Quote Originally Posted by viveks_911 View Post
    yes it does now my gps takes 5-10 sec for fix. Use method 2 install both app gps status and Toolbox + faster fix
