many many thanks to you for your very usefull post about hacking. Because at this moment devcer from nokioteca is cannot sign any hackin app without helloox2.03. Thanks...
hi guys i have a problem, installserver patch, have a X symbol and it wont apply, i also try to move installserver.exe to c://sys/bin but all the app. i try to install ,seys file corrupted
You will have to use the correct version of installserver to the C:\sys\bin folder bro.
Then u wont get the file corrupted error..!!!
And once u have moved the installserver to the path, uninstall rompatcher lite and install the rompatcher+ bro...!!
Then u can use the open4all patch..!!!
Dr Web : "This package can be installed on Nokia Devices only".
when i launched tha Drweb antivirus & goto quarantine, i didnt see anything there!!!!
...Live yur life as if God Exist
....If God exist den yhu will gain Eternity
.....If God doesnt exist den yhu have nothing to loose
Knowledge will give you power but character will give you Respect... 2Pac
Code:NypoN>>>Xperia P Silver>>>Jelly Bean (JB) 4.1.2<<<
Brother i try my n8 above said method but not successful.is it working n8? Anyone please tell me.
Simple And Dependable
Nice Thanksss
"I Will Die or Live Trying" Me
codrus is good team but where is the masters of school "binpda"
i did every step correctly with my C5-03 . but when run rompatcher+ app i got empty / blank . no files there . help me what should i do?
{★★★ Android N00B Guide ★★★}
{Root Your Phone}
Share your Pics captured by your Phone's Camera Here
