{★★★ Android N00B Guide ★★★}
{Root Your Phone}
Share your Pics captured by your Phone's Camera Here
Does all other antivirus hack use the same method to do it? I mean should i try some other method before formatting?
why not try other hacks brov....... can yu delete dose files?
...Live yur life as if God Exist
....If God exist den yhu will gain Eternity
.....If God doesnt exist den yhu have nothing to loose
Knowledge will give you power but character will give you Respect... 2Pac
Code:NypoN>>>Xperia P Silver>>>Jelly Bean (JB) 4.1.2<<<
They cannot be deleted as the files are in c/resources. It couldn be overwritten also by the antivirus
C:/resource??? Dey ought to be in C:/sys/bin/ but if yu cant delete dem den itz better yu restore yur cellphone brov but backup yur files first..... Have you try other hacks???
i tried it 0n my c6-01 and it's working...
thanks mate...
enjoy brov.......
Bri, i installed done the step 4, when i want to uninstall it, in application manager there are 4 files showing, which one i need to uninstall?
1.Norton Antivirus , 2. Norton Integrator , 3. Norton License Manager , 4. Norton Quarantine . which one i should un install it, what exactly i have to do, then what to do. me using Nokia N8 unhacked
Cheers
Sandy
--- Update ---
Bro, u r are a life saver
i done my N8 hacked. Thanx u Bro
me looking for it from so many days, u made my day
God Bless You
Cheers
Sandy
hey bro
vry nyc share....rep+
i have some confusion
at last step when i applied patches, open4all applied successfully
but install server.rmp gave a red cross
u said to refer to a gvn link
but from there i dwnloaded installserver.exe nw i'm stuck how to use this .exe file when for patch we need .rmp....
help.......................
works great on C7-00 v. 024.001
