Results 1 to 3 of 3
Thread: Help!!!!!
    Mar 2011
    india
    nokia n86
    Help!!!!!
    I have a nokia c7 locked to spain movistar network ....i want to unlock it
    can anybody help me?? plz
    May 2012
    Nokia 5233
    Default Re: Help!!!!!
    Hi,
    You can unlock your Nokia C7 using unlock codes!!! Unlocking using codes is easy and also safe!!! You can get the codes from your service provider or from any online sites!! I would suggest mobileunlocksolutions.com , they provide perfect codes at reasonable price!!! By specifying your phone's manufacture, model, country and network, you'll be able to get the codes!!!
    rajonpredate's Avatar
    Nokia C7-00, Samsung Galaxy SIII
    111.030.0609, 4.0.4 (Ice Cream Sandwich)
    i think u have downloaded the new firmware of 111.030.0610 which is only made for Spain Network.....always before upgrading your nokia use phoenix & in that always use allow to downgrade option....but till then i cant help you....but you have to wait till the new firmware gets on air.....& is possibility in next week.....sorrry my friend bha123.....or else search on net some latest firmware which is above 111.030.0610 & i recommend dont use unlock codes...!!!! to save you nokia phone....
