Results 1 to 7 of 7
Thread: help help to change nokia model number
    Apr 2011
    pune
    nokia 5235
    Default help help to change nokia model number
    recently i flash my nokia 5235 RM-588 with JAF tool ...when i check my model number it shows me 5230....can any help me how to fix it...any file name which store model number in fireware??? or any cooke methode pls tell???
    Jun 2010
    india
    nokia e51
    Default Re: help help to change nokia model number
    download genuine fw for your respective model(5235) and product code, and then again use jaf to flash, when you get files successfully selecte you will see a drop down menu just check the box which says change product code blah blah...
    --- Update ---
    check this imape you will see that drop down menu just below the green light. NEXT TIME DONT CHECK THAT BOX
    lh6.ggpht.com/_OgXs8V83nyg/SXXdhrfalXI/AAAAAAAAACs/CF-99-WNYMc/s1600/jaf%5B2%5D.png
    --- Update ---
    [IMG]lh6.ggpht.com/_OgXs8V83nyg/SXXdhrfalXI/AAAAAAAAACs/CF-99-WNYMc/s1600/jaf%5B2%5D.png[/IMG]
    Mar 2011
    Samsung Galaxy S2 i9100,Nokia 5230
    Download Original 5235 firmware (according to ur phone Rm & Product Code) from Phoniex or Nevifirm.. then again Flash Your Phone...
    To Know Ur 5235 Rm & Product Code Pls Open Back Cover and Battery Then You Can C Ur Phone Rm and Product Code (product code which is normaly 7 digit)
    Apr 2011
    pune
    nokia 5235
    thnx ...but Nevifirm not showing 5235 model number ...it shows Rm-588 for nokia 5230..from where i can download Rm-588 for nokia 5235..
    --- Update ---
    Quote Originally Posted by nishantj_2k View Post
    --- Update ---
    --- Update ---
    Apr 2011
    pune
    nokia 5235
    Quote Originally Posted by dakuaraja View Post
    Mar 2011
    1. Download Phoenix then open Phoenix
    2. open TOOLS menu under TOOLS click DATA PACKAGE DOWNLOAD then Enter your Phone PRODUCT KEY and Download the Formware
    3. flash the phone...............
    Dec 2012
    south africa
    nokia 5235
    v 50.6.001.c02.01
    hi i have a problem flashng my nokia 5230 i tryed to flash my phone tru jaf in offline mode because wen my phone is on its in offline mode but wen i flash i get this
    JAF version 1.98.66 beta5
    Detected PKEY: 90007BF6
    P-key nokia module version 01.02
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.92.0
    Changing mode...Done!
    Changing mode...
    Detected P-KEY: 90007BF6
    Init usb communication...
    Done!
    Reading product code...
    Product Code: 0598649
    Searching for JAF saved location of ini...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-588\
    Searching for default location of ini...
    Checking path: \Products\RM-588\
    Scanning ini files...
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.6.002_prd.core.C00
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.6.002_prd.rofs2.V13
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.6.002_C02_prd.rofs3.fpsx
    APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.6.002_000_001_U001.uda.fpsx
    Languages in ppm: English,Arabic,Farsi,Urdu
    Searching for phone...Found
    Reading SW version...ICPR72_11w10.1 50.6.001
    Reading battery value...4040 mV
    Init usb flashing...
    Reading flashid...
    CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
    APE: 00000000 <=> Flash -> not detected
    Verifing ADL communication... Status byte 7
    Rebooting to flash mode...
    Waiting for the phone to reboot...
    Error reading phone init data...
    can anny boddy help me pls what must i do now wen i get this messege pls pls help me
