anybody know Hard reset key for NOKIA E5-00??
brov....... try:- shift key, backspace or delete key, spacebar key den switch on tha phone...
...Live yur life as if God Exist
....If God exist den yhu will gain Eternity
.....If God doesnt exist den yhu have nothing to loose
Knowledge will give you power but character will give you Respect... 2Pac
Code:NypoN>>>Xperia P Silver>>>Jelly Bean (JB) 4.1.2<<<
*#7370# and enter password which 12345 by default unless you have changed it.
dats soft reset brov....
thanx bro, but (shift key, backspace or delete key, spacebar key den switch on tha phone) does not work. and *#7370# only wors when the phone is in fully working condition. My phone is starting but nothing show except white screen.
oooooooooops... brov i think ta best option is to flash tha cellphone brov!
ok brov, dnt worry... Am gonna drop a thread link or a tutorial for yu!
Always remember to Backup your phone before performing resets as your data may be lost. Its can erase more than Soft Reset But mork workful also.
Try the "3 Finger Deep Reset". Power off your Phone, Depress and hold these Threekeys simultaneously "*" "3""Dial key/Green phone" and Then power on phone using the on/off button whilst keeping the three keys Depressed until you hear start-up tone.
brov check here for tha tutorial:::::: http://montakhab.wordpress.com/2010/...-nokia-phones/
How to use Navifirm:::::::
PS::: Open the back panel to remove the battery and please note down the product code (Label with tha term "Code"), note down the type <RM-XXX> and firmware version of your mobile too.
Step 1:
Open NavifirmPlus.
Step 2:
Scroll\Search your phone model and match the RM code.
Step 3:
Now select the firmware version and download the firmware in accordance with the product code of your mobile to your computer.
Now create a folder with the RM code, which is same as that of your mobile. C:\Program Files\Nokia\Phoenix\Products\RM-XXX, Now copy all the firmware files to this location
Download Links::::::::
Phoenix:- http://www.4shared.com/file/F8--WdiT...are_2011_.html
NavifirmPlus:- http://www.symbian-toys.com/download...rmPlus_1.6.zip
Best of Luck brov....
