Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: [CFW] E52 Final BY Aftab Khatri (+100MB phone Memory)
    Feb 2012
    Philippines
    5800xm & E52
    v60.003 & v81.003
    Default Re: [CFW] E52 Final BY Aftab Khatri (+100MB phone Memory)
    bro.. gotcha.. thanks to this... =)
    --- Update ---
    bro theres a bug in the homescreen when i am using Contacs bar... when i apply the SwitchAllApplicationToTheFullScreen.rmp the contacs bar goes up.. suggestion please.. thanks.. =)
    Aftab_khatri's Avatar
    Online
    E6 Belle Own CFW
    Quote Originally Posted by jackardwin View Post
    --- Update ---
    that is not bug the patch do the all thef things just apply once exit menu and re-open menu dis-able the patch done u wont lose full screen in menu..
    Feb 2012
    Philippines
    5800xm & E52
    v60.003 & v81.003
    got it... thanks bro..
    Feb 2012
    Philippines
    5800xm & E52
    v60.003 & v81.003
    bro wen i am playing music... why does the music player says system error and the music player will no longer play any song at my library i have to restart my phone to play again music...
    Sep 2011
    Sky
    N70, E72 rofx hacked, 5250
    v5.0737.3.0.1, v071.004.C00.01
    nice work @Aftab_khatri
    draligus's Avatar
    Oct 2010
    tr
    e52
    i can't flash ur files phoenix says that rofs2 is missing..? i check it. there no such file in your folder
    draligus's Avatar
    Oct 2010
    tr
    e52
    i understand that rofs is not necessary.
    Mar 2010
    england
    e52
    hi, can you change your product code of your nokia e52? mine is 0585050 and i am not sure if i can do this change with my one??
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    Nokia E52,5730 XM, N97, N8, iPhone 3G, 4, 4S HTC Sensaion XL, Evo 3D
    054.003 & 5.21
    one problem i'm facing using ur firmware that music player hangs alot... it often freezes.. any solution to this ???
    IF YOU GUYS LIKE MY POSTING PLS PUSH REP++ & THANKS
    Online
    E6 Belle Own CFW
    product code not necessary
    when u flash u need to delet system folders from memrycard
