Page 2 of 17 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 169
Thread: Sygic GPS Navigation v12.1.3 + v13.1.0 + Maps Full
    Jun 2011
    Default Re: Sygic GPS Navigation v11.2.6 Full
    does this app has maps from india & south africa
    Jan 2010
    greece
    N95
    Can I install this version in Samsung
    Galaxy Y S5360?
    Samsung Galaxy S, Samsung I 8000, Sony Ericsson P1i
    Quote Originally Posted by 84jerry View Post
    You can find all Maps here--> Sygic-GPS-Navigation-Base-Files-MAPS-(Constantly-Updated)
    Quote Originally Posted by pfg View Post
    Galaxy Y S5360?
    Works in Android v2.0.1 and above.
    Jan 2011
    danmark
    htc desire hd
    thx for the upload , you are the one
    Jan 2012
    Croatia
    Samsung Galaxy S2
    When you say:
    "2. Download the Base Files(need not download if you're
    upgrading from v11.2.5) and desired Maps",
    which one do you mean?
    1.Base Files with English Voices & TTS :
    http://depositfiles.com/files/6ojfpycnu
    2.Mirrors :
    http://ul.to/aovfltv1
    or if I want some other language I should download
    3.Base Files with Multi-language Voices & TTS :
    http://depositfiles.com/files/zll7xqd8e.
    Next step:
    3. Extract/unrar and copy the file 'Aura' (the base files)
    each one of those three links have file Aura inside!! I am confuseeed, I lost my hair because of it
    Which one?
    Last step:
    4. Extract/unrar the Maps (the resulting folder should
    read something like 'xxx.yy.2013.01' )
    From where should I extract the Maps?
    Do I need to launch
    PC Map Downloader :
    http://extabit.com/file/27b5g0xc93tz3/
    and from there choose states to download the maps? Do I have to choose if I also want to download base files in PC Map Downloader?
    This is my first time to install maps to any mobile device. Please consider that and be gentle with explanation
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    the map is very Old (indian maps), j&k region is also not fixed like 2003 google maps, i think indian gov. can file a case on them
    JOIN FOR FREE ONLINE CLOUD/STORAGE:
    DROPBOX (max. upto 18GB.)-
    2GB.+500MB. Bonus
    MINUS.com (max. upto 60GB.)-10GB.+1GB. Bonus
    Join before its too late...
    Netherland
    HTC
    How can i get TTS voice of Dutch language?
    Quote Originally Posted by ringooo View Post
    When you say:
    2.Mirrors :
    Next step:
    Which one?
    Last step:
    Do I need to launch
    PC Map Downloader :
    Quote Originally Posted by saigon66 View Post
    You can find the Maps and Base Files with English/multi-language TTS from here:Sygic-GPS-Navigation-Base-Files-MAPS-(Constantly-Updated). If you want only English, download apk, base files with Eng.TTS and your map. If not, you'll need apk, multi-lang TTS and map.
    Once you've done that, in your PC, extract each file separately. Then follow instructions and place each file in the right place. Hope it helps.
    May 2009
    Brazil
    Galaxy SIII
    Is there TTS voice in Brazilian Portuguese?
    franklin84's Avatar
    Oct 2011
    Iceland
    SGS i9000 / i9100
    Online
    Hello!
    Someone got this holy shi* working with maps on external memory on SGS????
    I removed my old v11.2.2 completly and installed this version.
    Downloaded Base Files and some European Maps with Aura PC-Downloader
    and put them all to external_sd/Aura.
    I changed the paths in settings.ini from
    MapPath=/../Maps
    ContentPath=/../Maps
    to:
    MapPath=/../../external_sd/Aura/Maps
    ContentPath=/../../external_sd/Aura/Maps
    and changed the paths in database.xml
    Aura/
    to:
    external_sd/Aura/
    Anyone an idea where's my mistake?
    The app closed after a few of seconds :-/
    Thanks in advance! Frank!
