Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Sound improvement v3(for headphones) by iExtraX7
    MobilePhoneTalk Police
    arjunpaliath's Avatar
    Nokia C5-00/N73ME/N8 Black/5230-LG Optimus 2/Xperia X10 Mini Pro
    v061.005.022, v4.0839.42.2.1
    Default Sound improvement v3(for headphones) by iExtraX7
    Sound improvement v3 (for headphones) by iExtraX7
    This mod increases volume in headset. It works only for analog audio out(3.5mm).
    Add patch in to domain autostart, copy ParamServ from Z:/resource to C:/resource, unpack modded file to c:/resource/ParamServ, after that reboot the phone.
    Patch was made for Belle, but I think it will work on Symbian S^3 too.
    All sound mods will be added here. Old patch for loudspeaker you might to delete.
    Required
    1.Hacked phone.
    2.domainsvr installed
    If you still don'have it download domainsrv.zip attached and extract the files to
    a. C:\Sys\Bin
    b. C:\Sys\Hash
    Note the both the domainsvr files are different and needs to be moved to the correct folder in order for the patch to work properly.
    How To Install/Apply this Mod
    1.Copy ParamServ FOLDER from Z:/resource to C:/resource using x-plore like in screenshot.
    2.Extract 21)SoundImprovementV1.rar which contains two files:
    a. ChangeSoundParametersPath.rmp
    b. hrv_gain_tunings.rsc.
    3.Copy/move ChangeSoundParametersPath.rmp to c/patches(Rompatcher with domainsvr must installed to use this).
    4.Copy/move hrv_gain_tunings.rsc to ParamServ folder in C:/resource that you copied ealier
    Overwrite if prompted.
    5.Open rompatcher application and apply ChangeSoundParametersPath.rmp to Add to auto(domainsrv).
    6.Restart your phone and enjoy better sound quality in you headphones.
    Sound Improvement V2
    1.Extract to C:\ParamServ
    Will have more bass effect with softer touches
    Sound Improvement v3
    1. For more volume in headset and earpiece - unpack file from "MoreVolume" to "c:/resource/ParamServ"
    2 .For more quality and Bass in headset, as were in Anna - unpack all files from "AnnaParams" to c:/resource/ParamServ".
    -After that reboot the phone.
    MOD by iExtraX7
    Attached Files Attached Files
    ♠ The Administrator ♠
    Feb 2010
    Multan,PAKISTAN
    [HTC One X ,Iphone 3GS, HTC Explorer]
    HTC One X 4.0.4 Rooted,Iphone 3GS IOS 5.1.1 Jailbreaked with Redsn0w , HTC Explorer Rooted]
    Default Re: Sound improvement v1 (for headphones) by iExtraX7
    Today i tried this.............................sound are more clear and loud using headphones......
    Awesome Share buddy
    thanks
    reputation+++++++++++
    {★★★ Android N00B Guide ★★★}
    {Root Your Phone}
    Share your Pics captured by your Phone's Camera Here
    http://www.symbiantalk.net/signaturepics/sigpic33666_1.gif
    Oct 2010
    Philippines
    N808 / N8
    Alien Version
    tnx very much! Nice Rockin
    Default Re: Sound improvement v1 and v2 (for headphones) by iExtraX7
    V2 added..!!!
    Works better than V1 bro...!!!
    Jun 2009
    sweden
    n8
    you mean to C:/resource/ParamServ ??
    Excellent Poster
    Nov 2011
    india
    nokia 5233,Xperia tipo
    will it work for s60v5?
    Quote Originally Posted by karolsek93 View Post
    Yes extract to the location..!!
    But you should have the v1 installed..!!
    Quote Originally Posted by pintudada View Post
    No bro tested and working fine only in S^Belle only.
  8. #8
    Jul 2010
    Iraq
    nokia 5800 xp
    v 50.0.005
    it worked at belle or not?
  9. #9
    SELVASATHYAM's Avatar
    Feb 2011
    INDIA
    NOKIA C7-00
    Symbian Belle Official v111.030.0609
    v3 released...
  10. #10
    Quote Originally Posted by SELVASATHYAM View Post
    v3 released...
    V3 also added bro...!!!
    --- Update ---
    Quote Originally Posted by fairy88 View Post
    Compatible only with Nokia Belle bro...!!!
