...Live yur life as if God Exist
....If God exist den yhu will gain Eternity
.....If God doesnt exist den yhu have nothing to loose
Knowledge will give you power but character will give you Respect... 2Pac
Code:NypoN>>>Xperia P Silver>>>Jelly Bean (JB) 4.1.2<<<
This CFW is Wicked.WOW! It better then good and of course I should give some notes
If you put conversation mod it will be good. The new themes you've choosed is not that bad idea but they dont completely change icons, you can remove .acc - files except Email,Message,Alarm and Clock alert files. I think that's all. Will way the next realise)
hello Samur firmware rocks man!!!
seriously its to0 sleek and smooth!!
Thank you very much....
I just wanted to know tht how to uninstall the apps you pre integrated while cooking the cfw?
Data Quata not responding I cant reset it , plus that the app dont calculate the traffic
can u please post the link of that software which u use in flashing....??
--- Update ---
i am trying to flash my e5 from last 2 days....it always show me some error.....pls tel me the software u use to flash ur e5
This is the latest working phoenix flashing software, it works and it tested by me.
http://www.mobilephonetalk.com/showt...l=1#post299202
I am unable to use Nokia's built in 'Remote sim locking' option...please help....this error or bug u can say was found on two different nokia E5....running e5 extreme by sam v3
Great work Sam Pleasr leave your email address
can someone tell me how can i bring back my SPEED DIAL in normal.. i want to remove all the corresponding applications in every numeric in my keypad.. coz speed dialing is important to me.. please help.. thanks..
