Wave Control Pro v1.40
Requirements: Android
Overview: Control Your Music With a Wave of Your Hand!
Uses the proximity sensor on your phone to allow control of your music playback by waving your hand over your phone. No need to turn on your screen or even touch your phone at all!
As seen on:
*Lifehacker* http://lifehacker.com/5903676/wave-c...ver-the-screen
*Huffington Post* http://www.huffingtonpost.com/2012/0...n_1440305.html
*Pro Version*
-No Ads
-More Commands
-Assign Which Gesture Does Which Command
Coming Soon:
More Features - feel free to email any requests you have
Update the UI
Easy to use, just wave your hand over the sensor (usually located just next to the earpiece on your phone).
Holding it there will Pause/Resume
One wave across will go to the Next Song
Two waves across will go to the Previous Song
Three times (needs to be fast) will Pause or Resume the controls
*Be sure to enable Headset Button Control in your player of choice
Some Notes:
There is a little less than a second to register your waves.
Tip for the hover gesture: if you move your hand away too quickly it'll register a wave
After an action, there is a 1 second delay before another gesture will be registered
Will work with any player that accepts headset (media button) controls
If the screen is off or another app is in focus, phone vibrates once on pause control and twice on resume controls
Practice your wave techniques by checking the "Last Action"
If you're getting another player responding to the commands, check if that app has the option to disable headset button controls
**IMPORTANT**
I have read that the sensor will behave differently on different phones. I don't have the resources to have a bunch of phones around to test on. If there is a problem with the app, please email me at marksthinktank@gmail.com and give me a chance to figure it out before leaving a bad review!
And… there is a chance this app may not be compatible with your phone.. sorry. I'll do my best to keep the compatibility list up to date so future users won't run into issues.
Permissions Needed:
Wake Lock: So it will work when the screen is off
Read Phone State: So it won't do anything when you're on a call
Vibrate To use when screen if off or app not in focus
Download Instructions:Code:https://play.google.com/store/apps/details?id=com.MarksThinkTank.WaveControlPro
http://www48.zippyshare.com/v/30067717/file.html
