1Tap Cleaner Pro v1.52
Requipments: Android 2.1 and up
Description: Clear cache, search histories, calls log and defaults
1-Tap to clean all cache, search histories and calls log. A default cleaner is also included.
Are you running out of application storage?
You now can get more available storage space by clearing apps created cache/data files.
★ Cache Cleaner
★ History Cleaner
★ Call/Text log Cleaner
★ Default Cleaner
There are four cleaners included in this app. Cache Cleaner, History Cleaner and Call/Text log Cleaner help you to get more free space for the internal phone storage by clearing apps cached files, data files, or search/navigation history records. If you have selected to launch apps by default for some actions. Default Cleaner helps you to clear the default settings.
Auto or 1-tap to clear all cache, search history, calls log and the best is you don't have to ROOT the phone anymore! This app is crucial to anyone who has memory management issues.
★ 1-tap to clear all cached files
★ 1-tap to clear all search and browser navigation history records
★ 1 tap to clear calls log (incoming, outgoing, missed, frequently contacted)
★ list all default apps and clear selected defaults
★ home screen widget shows cache and available size
★ auto clear all cache and history at a specified interval
★ auto clear cache when the device is low on internal storage space
★ clear cache or history for a specified application
★ notify you on startup if more than 500K bytes cache used
★ list applications by either cache, data, code, total size or app name
★ view application on Market
★ uninstall application
★ open application
★ show application details page
Required permissions:
* READ_CONTACTS, WRITE_CONTACTS: show and clear calls log
* READ_HISTORY_BOOKMARKS, WRITE_HISTORY_BOOKMARKS: show and clear browser navigation history records
Same functionalities as "1Tap Cleaner Free" app, but Ad removed and more auto clear interval options added.
For user's manual, FAQ, please tap MENU > Settings > About for details.
Reviews:
★ http://goo.gl/EaSd8 (Video)
*** Note for Android 4 (ICS) users ***
* Cache cleaner will not work for Android 4.0.1/4.0.2 due to the the Android system bug. Google fixed this problem in 4.0.3
* Starting from Android 4, Android does not enable 3rd apps to clear the Frequently called log. You can manually clear it by: Launcher > MENU > Settings > Applications > All > Contacts Storage > tap the "Clear data" button
WARNING: This will delete not only the frequently called list, but also the entire call history log and contacts. As long as your contacts are backed up with Google, then they will automatically return within a minute or so when your phone resyncs contacts with Google.
Re-publish a new version, requested by Google. For aCCleaner Pro users, please purchase "1Tap Cache Cleaner Pro" and email your aCCleaner Pro order number to us for getting the refund. We're sorry for any inconvenience this might cause.
You have to install this app on the phone storage if you want to use the widget function. It's required by Android.
We have been selected as a Google I/O 2011 Developer Sandbox partner, for its innovative design and advanced technology.
Download: Released by chathu_acCode:https://play.google.com/store/apps/details?id=com.a0soft.gphone.acc.pro
http://1hostclick.com/kt6o0x4y6nci/1...v1.52.zip.html
http://turbobit.net/3sofvieku9jq.html
