Results 1 to 3 of 3
Thread: camERa problem...
    May 2012
    india
    Nokia E72
    Default camERa problem...
    hi... I have E72,
    i hacked nd install p@tch for turn off beep sound of camera,(a signed sis file).
    bt nw ma cmera is not working.....
    wen i try to open,its failed..
    i flashed ma E72 using phoeinix...
    bt still the problem going on.....
    how to solve it...
    plz...plz... HELP me.....
    """ADvanCEd ThAnKS..""
    StyXSIS's Avatar
    Aug 2009
    England (GB)
    N95-1 / Hkd with HelloOX v2.03
    v31.0.017
    Default Re: camERa problem...
    You haven't reset the phone, you have just updated the files that make it function.
    First reset the memory card so it has NO password at all or it will NOT work in the phone unless it's contents are deleted on a computer, then remove it from the phone. After that's done remove the sim card or the next process will not work.
    Holding all these buttons at the same time,
    Capslock
    Space
    Backspace
    on/off button
    until the Nokia "Shaking hands" logo appears will format the phone and delete any installed app that's screwing your phone up. If that doesn't work it is not a firmware problem, it's a hardware problem i.e, The camara is broken. Good luck.
    innocent mental's Avatar
    Jun 2012
    lahore pakistan
    nokia n95
    do hard reset ur problem will solved
