Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: avi player?
    Oct 2012
    USa
    samsung 5230
    Xmanoriginal
    Default Re: avi player?
    Have troubles in playing AVI in QuickTime because of codec issues? The problem is, QuickTime will only play AVI files that have audio and video.
    Signature Removed - Please Read Forum Rules
    Oct 2012
    USa
    samsung 5230
    "You may experience problems playing a video track in "filename.avi" because the required compressor could not be found."
    Oct 2012
    USA
    nokia 800
    You can use Smartmovie AVI Player for Nokia..thanks
    Banned
    Oct 2012
    USA
    nokia 800
    In the multiple options you can choose any technological device which suits your purposes best. However, there are some programs which you are completely bound to have in order to make your life less complicated, and Avi Player is definitely among them.
    thanks
    Oct 2012
    USA
    nokia 800
    AVI Media Player is a very easy to use video player. It can be associated with your AVI files so you just need to double click the file to play it.
    Nov 2012
    USA
    nokia 800
    Problem playing Avi files on my comp, HD files are ok. Guys, I have a weird problem, in the last few days when I try to play this format movies .
