Originally Posted by
haffid
Ok! To enable ALL the Tegra 3 (or iPhone 4s) effects, including Water on Floor:
0- Be sure you exit the game! ok?
1- Download ES File Explorer from Google Play (You can use the File Explorer that you like!! The thing is that you need an app that let you edit text files and permissions, and explore root folders)
2- In ES, go to Settings > and activate
* Root explorer (it's at the bottom)
3- Navigate to:
/data/data/com.madfingergames.deadtrigger/shared_prefs
4- Open the file called: "com.madfingergames.deadtrigger.xml" with ES Note editor
5- Change this lines:
This:
<int name="UnityGraphicsQuality" value="1" />
to this:
<int name="UnityGraphicsQuality" value="2" />
And this line:
<int name="OptionsGraphicDetail" value="2" />
to this:
<int name="OptionsGraphicDetail" value="3" />
and press menu and Save.
6- VERY IMPORTANT and/or OPTIONAL!!!!! Maintain tapped the file and press Properties, and go to "Changes" (next to Permissions)
and Un-check al the Middle, where it says "Write". In my case, i needed this.. Other users, like Product F(RED) doesn't.
7- Move the "com.madfingergames.deadtrigger.xml.BAK file to SDCard.. Don't let this .bak file in there!! (I recommend to move the .xml.BAK to SDCard because it has the "In game progress", so you'll need it if something goes wrong)
8- Play..
Warning
1- PLEASE DON'T TOUCH any other settings, because your game might crash.. ok? Only touch these ones..
2- The .xml file saves the game progress in a string.. So, if you delete it, you can lose your in-game progress..
I'm not using chainfire, because it's not needed in this game
