Page 12 of 18 FirstFirst ... 29101112131415 ... LastLast
Results 111 to 120 of 174
Thread: iGO PRIMO 2.0.1 ANDROID NavGear v9.6.7.235654 Final
  1. #111
    Dec 2012
    HTC One S; HTC HD2
    android 4.0.3
    Default Re: iGO Primo 2.0 Android Final Edition 2012 All Resolution Working
    I'm not satisfied with the zoom, when navigating in 3d.
    I can't find how to set the program, so i could come closer to the road and to the car indicator.
    I succeeded to change the zoom only to the minimal value of 40.
    There is a place to change this minimal value to a lower one, like in sys.txt, data.zip...?
  2. #112
    Jan 2013
    saudi arabia
    galaxy y
    Hi, the said files are not available at the given link. please refresh. Thanks.
    Quote Originally Posted by vladcepesh View Post
    where you download files?
    320x240
    http://directmirror.com/files/1U5DBRZW
    SD CARD\iGO\ui_android\common\keyboard.ini
    SD CARD\iGO\ui_android\common\keyboard.old.ini
    SD CARD\iGO\ui_android\common\ui\keyboard.lua
    SD CARD\iGO\ui_android\common\ui\keyboard.ui
  3. #113
    vladcepesh's Avatar
    Quote Originally Posted by hfarrukhn View Post
    in first page you are new links
  4. #114
    Jan 2013
    M
    sony experia s
    Default Re: iGO PRIMO 2.0.1 ANDROID NavGear v9.6.7.235654 Final
    Dear !
    Im new in this things , so I need a link for download Igo with resolution 1280x720 for Sony Xperia s , also please I need instruction for installation .
    Thanks in advance.
  5. #115
    Jan 2013
    GR
    Samsung GT-i5800
    Anyone has this problem with font size in 400x240 version?
    Everything works but this is a big problem as you cannot see what you are looking for.
    Also the fonts inside the ballons of street names are huge.
    Thanks.
    Attached Images Attached Images
  6. #116
    Feb 2013
    usa
    htc hd2 t-mobile
    Thank you THE ONLY version that works great on HTC hd2 !
  7. #117
    Sep 2010
    Greece
    I9000
    Can someone please give me a link buildings of Bulgaria
    Thanks
  8. #118
    Feb 2013
    france
    HTC desire
    pleaaase map of Morocco
  9. #119
    Feb 2012
    Turkey
    Samsung i9300
    ICS 4.1.2
    Default Re: igo primo 2.0 ANDROID Final Edition 2012 all resolution working
    iGO Primo 1280x720, 720x1280
    The file you are trying to download is no longer available.
  10. #120
    Aug 2010
    Slovakia
    Motorola RAZR XT910 | Motorola Xoom | HTC HD2
    Same probleme for me, with iGO Primo 960x540 :-( The file is no longer available ...
    Quote Originally Posted by heza View Post
