Page 2 of 18 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 176
Thread: iGO PRIMO 2.0.1 ANDROID NavGear v9.6.7.235654 Final
    vladcepesh's Avatar
    Default Re: igo primo 2.0 ANDROID Final Edition 2012 all resolution working
    Copy maps to folder map tom tom (ex. teleatlas)
    You not need to rename this maps
    I do not know whether it has navteq maps
    Oct 2010
    uae
    n8
    thanks alot it works perfectly........
    Quote Originally Posted by vladcepesh View Post
    MiddleEast NQ 2011 Q4
    Bahrain_NQ_2011.Q4_120109.poi
    Bahrain_R3_NQ_2011.Q4_120105.fbl
    Jordan_NQ_2011.Q4_120109.poi
    Jordan_R3_NQ_2011.Q4_120105.fbl
    Kuwait_NQ_2011.Q4_120109.poi
    Kuwait_R3_NQ_2011.Q4_120105.fbl
    Oman_NQ_2011.Q4_120109.poi
    Oman_R3_NQ_2011.Q4_120105.fbl
    Qatar_NQ_2011.Q4_120109.poi
    Qatar_R3_NQ_2011.Q4_120105.fbl
    Saudi_Arabia_NQ_2011.Q4_120116.poi
    Saudi_Arabia_R3_NQ_2011.Q4_120116.fbl
    United_Arab_Emirates_NQ_2011.Q4_120106.poi
    United_Arab_Emirates_R3_NQ_2011.Q4_120105.fbl
    http://www.directmirror.com/files/1E8WFKDP
    Buildings
    SaudiArabia.3dl
    UnitedArabEmirates.3dl
    http://www.directmirror.com/files/BK1LSDYR
    NQ is Navteq maps. You must have only navteq maps in map folder. Navteq maps not work together with Tom Tom (teleatlas) or Topmap. If you have other maps Tom tom, Topmap you must cut from map folder and copy to other folder (map_ot) and poi files to poi_ot
    Banned
    Jul 2012
    France
    HTC OneX
    Default Re: iGO Primo 2.0 Android Final Edition 2012 All Resolution Working
    Great post... Everything is here... Maybe somebody need create pack with fix for all resolurion like background, start and exit picture...
    vladcepesh's Avatar
    Quote Originally Posted by rponseeni View Post
    Please let me know whether India map is available or not? Thanks in advance
    iGO R3 India Navteq 2011.Q2
    http://www.directmirror.com/files/5FTRVMOM
    Apr 2012
    uk
    galaxy s2
    sadly google search feature is not working
    Sep 2010
    US
    Great post! Some of the pictures show status bar (with clock, battery remain...); mine does not. Anybody know how to enable it? Thanks
    vladcepesh's Avatar
    These are some examples in sys.txt change
    (without info bar) 960x540
    [rawdisplay]
    screen_xy="800_480:960x540/540x960:fullscreen"
    with task bar:
    (with info bar)
    [rawdisplay]
    screen_xy="800_480:960x502/540x922"
    (with info bar) 480x320
    [rawdisplay]
    driver=engine
    screen_xy="480_320:480x290/320x450"
    (without info bar) 480x320
    [rawdisplay]
    driver=engine
    screen_xy="480_320:480x320/320x480:fullscreen"
    the other resolution is similar
    Aug 2012
    Viamão
    Motorola Atrix 4G
    Hi! Thanks for sharing that great work.
    I have a little problem. I can't get past the 1st 'configuration screen'. iGO just freezes or closes (no erros, force closes, etc: just closes).
    In my iGO folder i don't have the "ui_android" and "ux" folder, maybe could that be the problem?
    I've used the iGO_960_540.apk and 960x540 sys.txt (also tried the 'multi-res sys.txt), with a Brazil.fbl ( NAVTEQ Q04 from here) and Voice_Por-bra-f1 - Gabriela v1.0 voice.
    Thanks in advance
    EDIT: Found the solution. I've removed my DCIN folder and everything runs fine. Looks like the iGO use the photos geotagged as POIs...
    I just can't use the SVOX for TTS :/
    Sep 2011
    Romania
    Samsung Galaxy S
    I need the ,,Buildings” file for Romania, it's missing from your Buildings folder on the link
    Sep 2010
    US
    [rawdisplay]
    with task bar:
    (with info bar)
    [rawdisplay]
    [rawdisplay]
    driver=engine
    [rawdisplay]
    driver=engine
    Thanks for your reply. Mine is 854x480 and I changed the sys.txt file to:
    [rawdisplay]
    driver=engine
    screen_xy="854_480:854x430/480x824"
    but it still did not show the info bar.
