Paypal Donation Available PM By Going Here For Details. Benefits In Return For Donations See Here
Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 185
Thread: iGO PRIMO 2.0.1 ANDROID NavGear v9.6.7.235654 Final
  1. #61
    vladcepesh's Avatar
    Re: iGO Primo 2.0 Android Final Edition 2012 All Resolution Working
    Quote Originally Posted by goran60 View Post
    Problem: Content error global_cfg not found.
    sd card----> iGO\content\global_cfg
  2. #62
    nanu_mihai's Avatar
    Sep 2011
    Romania
    Samsung Galaxy S
    Quote Originally Posted by vladcepesh View Post
    Vlad, I.ve seen that you posted a new link for maps- oktabar. Tehere are some changes from the September ones?
  3. #63
    vladcepesh's Avatar
    Quote Originally Posted by nanu_mihai View Post
    yes but Topmap 2012.07 not
    Top-Map Release Notes
    Albania 2011.07
    ____________________
    Bosnia And Herzegovina 2011.07
    Bulgaria 2011.07
    Croatia 2011.07
    Cyprus 2011.07
    Czech Republic 2011.07
    Estonia 2011.07
    Former Yugoslav Republic Of Macedonia 2011.07
    Greece 2011.07
    Hungary 2012.07
    Latvia 2011.07
    Lithuania 2011.07
    Montenegro 2011.07
    Poland 2012.03
    Romania 2012.07
    Serbia 2011.07
    Slovakia 2011.10
    Slovenia 2012.03
    Turkey 2011.10
    Ukraine 2012.03
  4. #64
    nanu_mihai's Avatar
    Sep 2011
    Romania
    Samsung Galaxy S
    thaks, unfortunately the folders are deleted
  5. #65
    sfa123's Avatar
    Feb 2012
    Russia
    Samsung N7000
    Prolema with a resolution of 1280x800. Not working full screen mode. Cut the lower part of pictograms. When you rotate the screen freezes. Samsung Galaxy Note (N7000).
  6. #66
    nanu_mihai's Avatar
    Sep 2011
    Romania
    Samsung Galaxy S
    search on my post with the app for note
  7. #67
    nanu_mihai's Avatar
    Sep 2011
    Romania
    Samsung Galaxy S
    I can not download that archive in any way
  8. #68
    Gladiatorius's Avatar
    Jul 2012
    Albania
    Samsung J5 2016
    Rom
    Android 4.2
    Hi, i do everything like you say and where i go to use to iGO Primo ,that says "please insert the iGO Primo SD CARD" If you can help me and tell me what i dooing wrong?
    THANK YOU
  9. #69
    Luluabc's Avatar
    Nov 2010
    Romania
    nokia 5800 XM
    Rom
    v.51...
    Quote Originally Posted by Gladiatorius View Post
    THANK YOU
    Hi, I had the same issue, but now it's working. All I've done is that I've changed in the "sys.txt" file, "sdcard2/...." to "sdcard/..." search this in "sys.txt" and change it, maybe it will work for you too.
    And I have a question, which resolution should I choose for Galaxy S2? Because 480x800 is not ok, here. Thanks.
  10. #70
    petraras's Avatar
    Jun 2010
    Cyprus
    Nokia E72
    Hi guys,
    I have a Galaxy Nexus running jb 4.1.1. I downloaded the 1280*720 files from the first post for the iGO folder and installed the thin 1.1 with the jb fix. I face two issues:
    1) Soft keys cover the bottom of the screen where buttons usually are (ok, back etc).
    2) The first time i installed it, it worked. After exiting the application and tried to open it again it loaded for few seconds and then nothing. It turns out that i have to wipe the data every time to make it run. Does this have to do with the DCIM folder? I tried to rename it to DCIM1 but it didn't work. I don't really get the instructions at the first post regarding the DCIM folder. Do i have to delete everything (including thumbnails folder)?
    Thanks in advance!
