you can not add manually i think..,
if you needed it you should put it to rom.
i dont understand it.last day i tried add to turkish language into v2 cfw.after flash phone doesn't open.when i tried another time the phone was open but turkish language is only display language.not writing language.
auto instalation is working.
how to add turkish t9 into cfw?... can someone help me? plz..
hi Bro. I copied ur rm645 to product folder. When pressed refurbished button it says ....rofs2 missing. What to do. Help. Thanks.
@Rnkhan7
download this file and then use rofs2 and rofs3 for final cfw.
http://www.mediafire.com/?s8omesj6sdd4n94
for more detail go to previous thread of sam
previous thread
http://www.mobilephonetalk.com/showt...FW-v2-0-by-sam
hi buddy! Thanks. Iwill download and install. But the previous thread says only core and uda are req. Can we flash with only two files? Plz guide.
download both of v2 and final cfw.copy rofs2 and rofs3 files from v2 cfw to final cfw.There should be 10 files with rofs2 and rofs3.but when you flash the phone you need only two file.core and uda.
Delete the red ones.
thanks 4 the help ugurc! This is the 2nd day i m trying to download cfw final ,but sometimes it reaches 20mb sometimes even 70mb but then it stops and becomes 0.i m using builtin browser and it has no resume option,operamini and uc browser are not downloading from mefiafire. Plz help. Thanks.
Buddy can u make this for E52 pls ????
IF YOU GUYS LIKE MY POSTING PLS PUSH REP++ & THANKS
