Page 3 of 11 FirstFirst 123456 ... LastLast
Results 21 to 30 of 106
Thread: Sygic GPS Navigation v12.1.3
  1. #21
    May 2012
    ARGENTINA!!!
    S2
    ZorroARG
    Default Re: Sygic GPS Navigation v12.1.3
    Black screen here, too. S2 i9100G ICS 4.0.4. Back to 11.2.6...
  2. #22
    Excellent Poster
    Roket
    Asus Prime / Xperia S
    Android 4.2+
    Quote Originally Posted by HelloOX View Post
    can some upload the links for the market apk ?
    Official v12.1.3 :
    http://uploaded.net/file/235pn0yj
  3. #23
    Sep 2010
    ET
    SGS i9000 + Samsung GT-P6800
    Stock ICS 4.0.4
    Thanks, buddy. Following the instruction, installation went well, and it seems working but persistent with GPS issue - inaccurate signal even with 3G Network on. Thinking of going back to the older version.
  4. #24
    Oct 2012
    The Netherlands
    Samsung Galaxy S2
    Android 4.1.2
    Works perfectly at my S2 i9100G ICS 4.0.4. now problems found (yet)
  5. #25
    Jan 2012
    OZ
    SE
    Just a question if you don't mind....
    Is this App able to update Map or download other country Maps after installing the cracked version of Sygic? Thanks
  6. #26
    Jan 2011
    Poland
    Xperia
    xperia s ics, working perfect, thank you
  7. #27
    Oct 2012
    germany
    samsung galaxy s2
    Quote Originally Posted by tc99c View Post
    NOPE because is written that you download maps BEFORE with trial version than is LOGIC you CANT download maps with cracked version
  8. #28
    Jun 2009
    Brazil
    XT 910
    V 4.0.4
    I installed Sygic 12 on my Motorola RAZR and it worked 100%. I uninstalled version 11 and delete the folder AURA. Once installed I was able to download additional TTS voice. Very good. Thank you.
  9. #29
    Jul 2012
    Pakistan
    Sony Ericsson Live With Walkman Wt19i
    how can i donwload maps??? coz they are also paid now
  10. #30
    Quote Originally Posted by gmp009 View Post
    Full instructions if used up 7 day trial
    download + install old sygic 11.2.6 from here http://www.mobilephonetalk.com/showthread.php?118329
    download required maps unfortunately it makes you download the old base aswell
    move the folder "maps" from sdcard/aura/ to new location e.g. sdcard/
    uninstall sygic 11.2.6
    install sygic 12.1.3 trial from market or original post 1
    run this and it should download the base files
    then once you get to the screen buy now you can download additional voices if you want but it won't let you download maps
    Close sygic
    rename sygic folder in sdcard/ e.g. to sygics
    copy maps folder into new sygics folder
    uninstall sygic 12.1.3 trial
    install cracked sygic 12.1.3 from original post
    then change the sygics folder back to sygic
    should now be working
