• Special Opening and Closing Screenshots added
• Pack Symbian Anna was used İcon
• Added Symbian Anna Notices
• Writing Average Mode is used
• Vertical and Horizontal Large Icon Mode is used
• Top-down Klawyede Key Confirmation Receipt
• By default, all themes Deleted
• 2 Opening Theme Added Red Nokia Hd 5s set the theme with the theme of looking after the image porche
Performance Mods
• The battery time brought the best layout
• Power Save Mode Added
• Touch Sensitivity brought the best layout
• The sensor layout was brought to the Best Rate
• Touch Sensing and Function of the layout was brought to the Best Rate
• Theme Preview accelerated time
• Application response time accelerated
• Streamline brought to Best Wifi Sensitivity
• Timeout 1 sec to 0.5 sec when typing İndirldi
• Screen Refresh Rate 22 fps to 30 fps Upgraded
• Heap (heap) Size Increased
System Modes
• Port C6 5800 - V42 V60.003
• Language Turkish and English
• Menu Layout set to 4x4
• Earned ID 5800
• opening the drop-down Unnecessary Applications Closed
• Cancelled Applications Running in the Background
• Nokia Pure Font used
• Removed the Control of Fota'dan Update
• Removed Transaction Recording Time 365 day
• The default Handset Volume Adjusted to 100%
• Java warnings Allowed
• Wi-Fi positioning Option Added
• Removed menu options Help
• Removed menu options Show Open Applications
• Applications can be sent by Bt
• Decertified Software Download
• The scanner Cache (E) When inserting the Memory Card Receipt • Headset Accessories Selector Menu Added
• Allowed to send via Bluetooth Implementations
• Key lock: Yes Added C5
• Option Added Resume aborted downloads
• Restart Option Added
• The camcorder will shoot 1 Silent Voice When selected,
• Setting the Default Date (20/11/2012) set to
• Vertical and Horizontal Scroll Bar Removed
• Deep Cleaning Done (846 kb Empty Deleted Files)
• Display Light Sensitivity Added
• Memory card icons on your page Added (appears in the upper right corner of each floor)
• Time Zone Update Added
• Extra Sensor Settings Added
• Keyboard Added N8
After that first turned on the device Break mb ram 58 59 53 54 mb tan normal use, does not fall down
Hassle Free Qt Applications Qt Components installed on your device, you must install
Abolished the software
• Drawing
• Zip Manager
• Quick Office
• Adobe Reader
• Welcome
• My Nokia
• About
• Phone Switch
• Converter
• Images & Printing
• Help
• Effective Notes
• Installation Akses
• Ovi Contacts
• Ovi Sync
• Ovi Music
• Here And Now
• Online Sharing
• Video Sharing
• Internet Phone
• Chat
• Podcasting
Those software
• Default Applications
• Ovi Store
• Ovi Maps
• Voice Recorder
• Dictionary
• Software Update
• Voice Commands
• Setting Wizard
• Message Reader
• Operator Menu
• Accell Switch
Legal Notice
Tampering, SHARING IS STRICTLY PROHIBITED played in
I got out of this than I do trust the writings of haqan erased Posts modlamaların
And then format the memory card before installing cfw and hard format Or Take Your device may not work properly
