Why not just use the extsd2int script? This gives you your whole external SD to use.
Well I never heard of that, would you give us some details?
OK I ran into a problem where I had to reset my phone and reroot it.. Now when I try to set everything up when i go to transfer data it starts as sdcard0 but when it searches its only sdcard.. Is there a way to fix this?
When I use file manager to make sure the data I need is there it's under sdcard0/android but when I run directory bind it doesn't find sdcard0 it only shows sdcard/android
@holdmyown: I read there is a problem with this. Are you using Android 4.2 I think Directory Bind doesn't work there.
