This app is designed for both iPhone and iPad
Category: Utilities
Updated: Nov 14, 2012
Version: 3.5.1
Languages: English, Chinese, Japanese
Seller: Curt Schilling
© CSMOB
Requirements: Compatible with iPhone 3GS, iPhone 4, iPhone 4S, iPhone 5, iPod touch (3rd generation), iPod touch (4th generation), iPod touch (5th generation) and iPad. Requires iOS 3.2 or later
Description
✭✭✭ THE HOT APP! ✭✭✭
✭✭✭ FEATURED ON THE APP STORE! ✭✭✭
✭ View files, see movies and play musics in one software! ✭
"The most practical USB flash drive app on the App Store!" - Eric Cowboy, CSMOB ✭
FEATURES:
✓ Store and view files on your iPhone/iPad/iTouch.
✓ Support PDF, MS Office documents, iWork documents, JPG, PNG, GIF, HTML, TXT, MP3, WAV, MOV, M4V, AVI …
✓ Use the huge available space on your device.
✓ Protect access to your files by creating a password.
✓ Fast USB file transfers.
✓ Support WIFI transfer.
✓ Compress file.
✓ Share file with Email.
✓ Sort, delete, duplicate and rename your files.
✓ No need to study. Easy to use.
✓ One solution for iPhone, iPad and iTouch.
✓ Compatible with Windows 7 and Windows XP.
MORE FEATURES WILL BE AVAILABLE SOON!
✓ Cloud storage
✓ Create folders
If you like my product, please follow me at twitter http://twitter.com/curtschillingcs.
What's New
-Fix Wifi bug for Windows
http://ul.to/0axdcdkx
http://letitbit.net/download/89762.8...3.5.1.ipa.html
