Results 1 to 3 of 3
Thread: R battery savers safe?
    Excellent Poster
    Nov 2011
    india
    nokia 5233,Xperia tipo
    Default R battery savers safe?
    R battery savers safe to use friends?
    Android > All
    tipsek's Avatar
    Mar 2011
    Galaxy
    Note 2 / Nexus 7
    Default Re: R battery savers safe?
    What do you mean safe to use? I will tell you like this, I tried a few but results were nothing spectacular. They can help a bit, but there are better ways for saving battery yourself. Screen, 3G, WiFi, GPS and such are the biggest energy wasters. So you can do a lot just by lowering the brightness a bit and turning wireless modules off when you don't need them.
    shofi's Avatar
    Oct 2009
    On Your Mind
    SGS2 <> Nexus 7
    Android 4.1.2 <> 4.2.2
    If you are lazy battery saver can save some like automatically turn off some stuffs like wifi, gps, screen brightness etc. Only way you can save battery by using custom kernel and tweak cpu according to your need.
