Results 1 to 4 of 4
Thread: Deep Sleep Battery Saver Pro v1.51
    Jan 2012
    Pakistan
    Galaxy S3 - i9300
    ICS v4.0.4
    Paid Deep Sleep Battery Saver Pro v1.51
    Current Version: 1.51
    Requires Android: 2.1 and up
    Category: Tools
    Deepsleep battery saver constantly puts the device to deepsleep mode while screen off
    LifeHacker: “Plenty of apps save your battery life, but this one takes the idea to a whole new level”
    During deepsleep mode, Wifi, 3G are turned off, background apps are stopped. Therefore, most apps are not working, including Facebook, Google Service, etc,. It then constantly wakes up in order to download email, sync Facebook status, etc,. It’s defined by deepsleep frequency and woke up duration
    In advanced mode (PRO), you can customize more parameters, including day/night settings, active period, screen timeout, sync strategy, ignored apps, etc,
    Features
    ☆ 5 pre-defined profiles: Gentle, Balance, Strong, Aggressive, Slumberer. They varies on frequency, duration and other settings. The former is less disruptive, but save less battery and vise versa
    ☆ Custom profile (PRO) – for advanced users. If you need more customization, select this profile and modify it
    ☆ Custom profile settings
    - Separate between weekday vs weekend settings
    - Frequency: device is turned on DS mode at a selected frequency
    - Duration: device is woke up after for a selected duration after a each frequency cycle
    - Wileless & network: control radio setting during DS on
    - Sync: Control sync strategy and sync account, auto-sync
    - Apps: Select apps that will be stopped during DS on
    http://www.hotfiles.co/1857C2545/download.html
    http://hulkload.com/sdojngpoou4k.html
    Apr 2010
    Portugal
    Galaxy S2
    Default Re: Deep Sleep Battery Saver Pro v1.51
    Mirrors please.
    Thanks
    Aventador849hp's Avatar
    Mar 2012
    Malaysia
    Atrix™2 MB865,Nokia N81,Nokia 5610
    CM10.1 Android 4.2.2,S60v3 v24.0.002,S40v5 v10.00
    Moderator
    f000h's Avatar
    Mar 2010
    Honduras
    Droid
    Old version! New version v1.6 already posted here http://www.mobilephonetalk.com/showt...Saver-Pro-v1-6
