[Leak] LG Optimus G Pro screen 5 "Full-HD, S4 Pro, 2GB RAM, 13 MP camera, 3000 mAh battery
Although less than one year since the official launch in August 2012, but it looks like the LG Optimus G about to be his successor, by some sources have recently revealed simultaneously Korean electronics conglomerateis beginning to develop a device called the Optimus G Pro. In particular, news site Engadget also give us images for the final design of the current high level. Based on the leaked photo, we see the difference of G Optimus Pro and the previous version is the appearance of the physical Home button, besides G Pro screen size larger. If you look carefully at the small picture, you can also recognize clusters camera, LED Flash on the Optimus G Pro has been moved toward the center, rather than in the left corner as before.
Hardware configuration changes, the most significant upgrade LG Optimus is expected to bring G Pro main screen. Specifically, with this release, LG has equipped its screen 5 ", Full HD resolution, pixel density at 443 ppi - similar to HTC Butterfly, OPPO Find 5, or Xperia Z. Some information about the configuration of the machine, such as quad core 1.7 GHz CPU, battery capacity is increased to 3000 mAh, 2GB RAM, LTE connectivity support.
The hardware configuration is for the LG Optimus G Pro
Screen 5 "resolution Full-HD, 1920 x 1080;
CPU Snapdragon S4 Pro, quad-core, 1.7 GHz;
2GB of RAM;
32GB of internal memory;
3000 mAh battery;
4G LTE support;
Camera 13MP, camera 2.4 MP;
Weight: 160g;
Size: 139 x 70 x 10.1 mm;
OS: Android 4.1 Jelly Bean.
