Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Nemesis Service Suite Beta 1.0.38.15 & Its Tutorials [Change Ur Product Code]
    jassa90's Avatar
    May 2009
    in your heart
    Nokia c7-00
    Belle Refresh
    Re: Nemesis Service Suite Beta 1.0.38.15 & Its Tutorials [Change Ur Product Code]
    Quote Originally Posted by jassa90 View Post
    Thanx bro good luck for ur exams.
    Will it work with n73 and on windows 7???????
    can i change the product code?and what is the risk?
    my n73's product code is 0543843
    Hey Its work.
    I changed my phone's product code.After it i checked via NSU for update and it worked
    Now my phone is updated with latest version 4.850.43.0.1
    THANXXXXXXXXXXXXXXXXXXX BRO
    For More info check this linkhttp://www.symbiantalk.net/showthrea...-v4-850-43-0-1
    Dec 2009
    LG Optimus One
    Default Re: Nemesis Service Suite Beta 1.0.38.15 & Its Tutorials [Change Ur Product Code]
    Quote Originally Posted by szaszaboy View Post
    I got "READING VALUES...ERROR" message after I push the READ button!Can anyone help?
    Do this:
    > Install Nokia PC Suite and take Content Backup of your device.
    > After backup, without disconnecting your phone run Nemesis Service Suite.
    > Follow the NSS procedure. Now it should read the data.
    Please revert back if this idea works.
    szaszaboy's Avatar
    Dec 2009
    Hungary
    5800 XPressMusic
    V52.0.007
    Quote Originally Posted by modifii View Post
    Do this:
    Thanks for the help man!It works!!!
    Jul 2010
    Nokia 5800 XM C6
    v 51 With C6 FW Modded By Me
    hey it dont work for C6 nokia 5800 it shows read error tried all things
    Moderator
    ravish_919's Avatar
    Jun 2009
    HTC Sensation XE, GPoisoned iPad, HTC Desire
    Android 4.0.4 wtih Sense 4.0
    Quote Originally Posted by japanpatel View Post
    Read the instructions properly & try the procedure again...
    Sep 2010
    Philippines
    N82
    thanks a lot.. worked on my nokia n82!
    Sep 2010
    Philippines
    Nokia N73, N76 & 5800 v52
    Re: Nemesis Service Suite Beta 1.0.38.15 & Its Tutorials [How to Recover Lost Security Code]
    THANKS ravish_919
    VERY GOOD INFO.
    Jan 2011
    Ireland
    Nokia E5
    Hi Ravish. No luck with Nokia E5 as well I installed the driver as well but still get the NSS cannot detect the phone at all. any suggestions..
    fastfinger's Avatar
    Jan 2011
    Zagreb
    C7
    PR 1.2
    @drsins
    you are probably using Win7...I had the same problem...it seems that newer Nokia Connectivity Cable Drivers don't work with Nemesis so you need to download and install the drivers given in this tutorial. I tried to install them on win7 but it didn't work, nemesis couldn't read from EEPROM even when I installed the drivers given in this tutorial....
    when I tried the same thing on WinXP it worked and I succesfully restarted Lifetime on my phone.
    My guess for win7 would be to uninstall the PC suite/Ovi suite or both and then try to install the drivers again (i didn't try this though).
    MY QUESTION would be, How to CHANGE, not just RESTART the lifetime on a nokia phone.
    the original reading of my device was : 0=000000000000000000000000000000000000000000000000 000000000000000026C50D00 (about 251 hours)
    the lifetime that restarts to zero is naturally: 0=000000000000000000000000000000000000000000000000 000000000000000000000000
    How do i set it to, let's say 70 hours??
    thanks in advance
    Mar 2011
    united kingdom
    C7
    does this work for symbian ^3 phones yet?
    i have nokia C7
