Page 1 of 18 123411 ... LastLast
Results 1 to 10 of 178
Thread: How To Upgrade Firmware Offline Or Flash Dead Phones Using Phoenix Or JAF Service Suite
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Default How To Upgrade Firmware Offline Or Flash Dead Phones Using Phoenix Or JAF Service Suite
    Using JAF See Post 2
    This tutorial can b used to flashing of dead phones.
    BTW, this works for XP n Vista, x86 or x 64!!!
    Tools Required:
    1.Phoenix Service 2012 suite:
    http://www.mobilephonetalk.com/showt...d-amp-Original
    2.Navifirm:
    http://www.mobilephonetalk.com/showt...Codes-amp-More
    Before Flashing:
    - backup your phone number and phone number of important personal information. If you want a clean installation, format your E: drive as well using the built in Nokia file manager .
    Lets Start…….
    ->Run Phoenix Service Software installer.
    >Start Installing Phoenix
    -> Now (the boring part) run Navifirm (it takes an hour or more to download the whole patch)…
    Note: the reason i don’t use the builtin image downloader because it downloads older versions, from my experience.
    After the files downloaded, copy them to C:\Program Files\Nokia\Phoenix\Products\RM-XXX\
    XXX - use your product code
    ->Now Run Phoenix 2009
    [if you have dead phone use Dead Phones Flash? To being able to tick dead phone flash delete the usb connection in phoenix. then make it go into "no connection". then open the rm-xxx. the dead usb flashing will now be enabled.]
    ->Turn on the phone (it will start in offline mode because there is no SIM card inside).
    ->Plug in the USB cable to both the phone and the computer.
    ->When prompted, select “PC Suite” from the menu list on the phone.
    ->Wait for *all* drivers to fully install themselves before proceeding. You will see the driver icon disappear when it is complete.
    -> Now Choose File Then Manage Connection
    ->###### “New”
    ->###### USB, and then ###### Next
    ->It will then search your USB ports for the phone. When it finds it, hit Finish
    ->Once it has finished scanning, ###### apply, then ###### close.
    ->Next, select “Scan Product” from the File menu.
    -> Once finished scanning, you can see your model of phone and other details at the bottom screen.
    ->From the Flashing menu, choose Firmware Update.
    ->Wait for Phoenix to continue talking to the phone. You will see some information scroll by in the firmware Update window.
    ->###### Browse
    ->See the product code section.U should find ur product code in that column.If u see “ur” product code,well and good.
    -> but if u dont see ur code,or dont see anything for that matters,press on the “…” in the given prCode section.
    You should see RMxxx-blabla, select that. Variant version =00. I will select “Refurbish” so that it will restore it to factory set (Clean and default C.
    ->Press Start
    Ignore the warning and click YES
    The flashing process takes about five minutes to complete. The first few steps ensure connectivity to the phone.
    After it verifies connectivity,Phoenix will automatically restart the phone.
    Once it has completed (a dialog box will popup saying it has completed successfully), you may close Phoenix,
    unplug the USB cable, and restart your phone. It should startup with the firmware you flashed to it.
    CRC Checksum Error Solution For Phoenix When Flashing CFW
    http://www.symbiantalk.net/showthrea...n-Flashing-CFW
    For make it more clear here is a video thanks to chandarakk:
    Attached Images Attached Images
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Default How To Flash Dead Phones Using JAF Service Suite
    some people having dead phone for using PHOENIX And that happens because the ADL server checks the CRC after the firmware upgrade, which won't match because you cooked your firmware files and will cause the boot-loader not to change back to normal operating mode. So DO NOT USE PHOENIX when upgrading CORE, ROFS2, ROFS3 cooked files, use JAF only...
    INSTALLING AND SETTING UP JAF
    1. Download this file
    http://depositfiles.com/files/u1rwi536v
    [Thats Include All File You Need]
    2. UNRAR the file to your desktop
    3. open the folder
    4. install JAFSetup_1.98.62.exe
    5. install JAF to the default location
    Note on you only have to do "this" if you are using Vista, Windows 2003/2008 server. or Windows 7
    A. Right click on "OGM_JAF_PKEY_Emulator_v 5.exe"
    B. scroll down to "Properties", left click on "Properties"
    C. Left click the "Compatibility" at the top of the popup window.
    D. "CHECK" run this program in "Compatibility" mode
    E. In the select box. select "Windows XP" or Windows XP SP?
    F. left click "APPLY", then left click "OK"
    GETTING YOUR FIRMWARE DOWNLOAD AND READY FOR FLASHING
    1. go to "C:\Program Files\Nokia".
    2. create a folder called "Phoenix" > C:\Program Files\Nokia\Phoenix
    3. open C:\Program Files\Nokia\Phoenix
    4. create a folder called "Products" > C:\Program Files\Nokia\Phoenix\Products
    5. open C:\Program Files\Nokia\Phoenix\Products
    6. create a folder with phones ROM VERSION > RM-xxx, C:\Program Files\Nokia\Phoenix\Products\RM-xxx
    7. open C:\Program Files\Nokia\Phoenix\Products\RM-xxx, leave it open. xxx - your Rm version
    8. go here http://www.symbiantalk.net/showthrea...uct-codes-more
    10 download your firmware using "navifirm.exe"
    11. save your firmware to > C:\Program Files\Nokia\Phoenix\Products\RM-xxx
    Note...
    RM-xxx will be different depending on your country or region (IE, RM-505, RM-555, etc...)
    USING JAF TO INSTALL COOKED ROMS
    12)Install Nokia pc suite if you dont have it installed already (Cable Drivers Are installed with them and needed)
    1. from main "jaf" folder.
    3.click on "OGM_JAF_PKEY_Emulator_v 5.exe" then Click Go
    4. JAF gets loaded
    6. in JAF left click the BB5 tab
    7. under "Flash Settings"...
    A. uncheck "CRT 308"
    B. check "Manual Flash" "Dead USB"
    C. check "Normal Mode"
    D. check "Use INI"
    8. Wait for INI popup window to open.
    [Then a list will appear containing all phone models like the picture below]
    9. scroll down to your USB FIRMWARE CABLE TYPE
    10. Select firmware type (RM-???)
    If JAF doesn't find the RM-xxx, just add the following two lines to the end of the file jaf_nok4models.ini (normally found in C:\Program Files\ODEON\JAF\):
    [RM-xxx]Description=Nokia X6 CABLE [RM-XXX Write your RM version in xxx , write your phone model replacing nokia x6]
    Note RM-??? will be your country or region type
    11. left click "OK"
    12. your FIRMWARE FILES ARE SETUP AND LOADED READY FOR FLASHING BY JAF
    13. Turn Off Your Phone connect it to your pc.
    14. in the "Operations Box", left click on "FLASH"
    [Then Click YES when a dialog appears like on the picture below]
    15. then Jaf will ask for turn on your phone click turn on [Now Just press the Power Button on your phone a little (just for about 1 second)]
    15. Wait for JAF to start flashing
    16. after flash complete your phone will auto start
    It's that simple, you won't ever brick your phone if you do this way.
    JAF install pack, everything you need download from here
    http://uploaded.to/file/fxjr5y
    Flash Log Thanks TheOne:
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    P-key nokia module version 01.02
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.29.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Searching for JAF saved location of ini...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-559\
    Searching for default location of ini...
    Checking path: \Products\RM-559\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_prd.core.C00
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_prd.rofs2.V19
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_C03_prd.rofs3.fpsx
    APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_001_000_U001.uda.fpsx
    Detected P-KEY: 90009699
    Init usb communication...
    PRESS POWER ON NOW! Searching for phone...Found
    Error reading phone init data...
    PRESS POWER ON NOW! {if you are using dead phone usb mod}
    Sending RAW loader...
    Using 009.012.005
    Elf2flash 09.11.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step2...
    Patching RAW boot step3...
    Sending RAW Loader...
    ....................Loader Sent!
    Stage 2 starting................PUBKEYS already sent...
    ..........Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 586, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_prd.core.C00...
    Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
    Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
    Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
    Erasing cmt zone 00D60000 - 0B71FFFF ... Erase result: 0000
    Partition result: 0014
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_prd.rofs2.V19...
    Erasing cmt zone 07920000 - 0A2FFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_C03_prd.rofs3.fpsx...
    Erasing cmt zone 0A300000 - 0B71FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_20.0.005_001_000_U001.uda.fpsx...
    Erasing cmt zone 0B720000 - 1EF7FFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for ADA
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for RAP3NAND
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for SOS*UPDAPP
    Sending CMT HASH for SOS*DSP0
    Sending CMT HASH for SOS*ISASW
    Sending CMT HASH for SOS+CORE
    Sending CMT HASH for SOS+ROFS1
    Sending CMT HASH for SOS+ROFS2
    Write result 27: 1701
    Sending CMT HASH for SOS+ROFS3
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    MCUSW: V ICPR72_10w04.5
    22-03-10
    RM-559
    (c) Nokia
    APESW: V 20.0.005
    VariantSW: V 20.0.005
    Prodcode: 0589421
    Done!
    Some video to make it more clear :
    Flash Dead Phones Using JAF Service Suite Video Tutorial
    Download JAF 1.98.62:
    http://ul.to/j0t065
    Download JAF 1.98.62 with PKEY Emulator v5
    Firmware Flashing via JAF Service Suite
    Dead Phone Flashing Recovery via JAF Service Suite
    Nov 2009
    Netherlands
    N86 8MP
    v30.009
    Default Re: How To Flash Dead Phones Using Phoenix Or JAF Service Suite
    RAJU MATE U ARE MY HERO MAN, THANK YOU SO MUCH, my n86 is working again THANKS THANKS THANKS THANKS THANKS m8 REP+
    Feb 2010
    Nokia 5800
    Default Re: Using JAF to install cooked ROMS (N97/N97 mini)
    Hi,
    I have a nokia e65 and im having problems (its a brick), I cant seem to connect to PC Suite..."USB device not recognized" error. I have done the rest and still its just brick for me....any help would be appreciated.
    Kunal
    Apr 2010
    Switzerland
    n97
    YEESSS it works... MEGA THX THX THX THX 4 this guide... i am so happy i could explode^^ YEAHYAAA
    My N97 v 21 was dead but with this HOLY guide its now alive.
    Jun 2009
    greece
    n86 v30 hacked
    why when i press flash says phone not found? somebody help....!
    Jun 2009
    greece
    n86 v30 hacked
    now stop at step two.what i do wrong???????
  8. #8
    Quote Originally Posted by julius4364 View Post
    If JAF doesn't find your phone, just add the following two lines to the end of the file jaf_nok4models.ini (normally found in C:\Program Files\ODEON\JAF\):
    like :
    [RM-559]
  9. #9
    rudim35's Avatar
    May 2010
    indonesia
    Nokia E5, E63
    I have e75 ver 210.12.15 how can i hacked my phone with jaf or phoenix ,what file do i have
    thnk you
  10. #10
    Legend MPT
    andrew's Avatar
    Dec 2009
    Quote Originally Posted by rudim35 View Post
    thnk you
    use this bro E75-v210.12.15-RM-412-Hacked-by-PNHT-Method[COLOR="Silver"]
    [B][CENTER]“What is ‘real’? How do you define ‘real’? If you mean what we can taste, smell, hear and feel then what’s ‘real’ is nothing more than electrical signals interpreted by your brain.”[/CENTER][/B]
