Did you download latest sygic keygen
Before Start Posting In SymbianTalk.net / Mobilephonetalk.com Read This Rules
Post Your Photo Here & What Is Your Favorite Song Right Now?
If License Verification Require On My Paid Apps/Games Try To Use Latest Lucky Patcher From Here
If You Have Downloading Problem from FileHost / Cyberlockers Post Your Problem Here Or Use Free Downloader Site From Here
same problem here. then i tried using mm 9 v 7.71 and it worked! uninstall and switched back to mm 10 and failed. mm 10 seems to have different mlm structure than mm 9. and the guides lying everywhere all actually points to mm 9. mm 10 seems to only allow 1 mlm file for each map. using raju's sample for malaysia, theres 3 parts in the file namely, DEFAULT, EXTEUR and mys. this makes mm 10 ask for 3 different product activation, whereas keygen only provide a single code. heres what i did:
SMM10 Malaysia.mlm
[PRODUCT:SMM10 Malaysia]
name=SMM10 Malaysia
tts=no
sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
maps=TA:MYS:2009.03
SMM10 Singapore.mlm
[PRODUCT:SMM10 Singapore]
name=SMM10 Singapore
tts=no
sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
maps=TA:SGP:2009.03
2 mlm files placed in Maps folder
get codes for both mlm from keygen (device id is constant)
place maps in their respective folders. must correspond with the map line in mlm file. in my case, MYS and SGP. not sure if caps is required
the rest is the same as raju's instructions.
good luck!
yantz
@raju
the malaysia,singapore map link you provided contain several files but none of them is .pak. my guess is the pak is unpacked. can someone provide a link for pak handler so that i can try packing them into .pak? yes i've googled but they all link to those sites that my ip is always downloading something when i'm obviously not downloading anything. thx!
yantz
Sorry for Last post old method
The MLM file for your original maps needs to be the new format.
example MLM for malaysia for Sygic 9, this one cannot be activated in 10
[DEFAULT]
version=1.2
majorVersion=7
sdk=no
[IDN]
provider=TA
mapRelease=2009.03
detail=full
7digitPostals=no
example MLM for Sygic 10, this can activate with the keygen
[PRODUCT:mys]
name=malaysia
tts=no
sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
speedcam=no
maps=TA:mys:2009.03
I am having the same problem on my Hero
I have the following file structure on my SD card
sd\drive
sd\maps
sd\res
sd\maps\grc\grc.pak
sd\maps\wcl\wcl.pak
sd\maps\licence.txt
sd\maps\SMM10 Europe.mlm
sd\maps\SMM10 Greece.mlm
I have activated Greece.mlm successfully (apparently) but it still states that no map is loaded
My SMM10 Greece.mlm text is
[PRODUCT:grc]
name=greece
tts=no
sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
speedcam=no
maps=TA:grc:2009.03
Any help gratefully accepted!
Hi,
Thanks for the sweet program!
Its not the .mlm file I think. I had the same problem. In the tutorial the OP forgot te mention that you have to unpack the map because now it is a .rar file. Unpack it and you should be fine. Well I was after unpacking.
It runs fine on my G1. Had to get used to the responsivity but that’s the program.
Does it work to plan a route where your destination is on an other map across the border? Because you have to select a map. Didn’t have time to test it. Does anyone have experience with this? In Europe the counties are not so big and when you live near a border it would be very useful if it worked.
Thanks again.
Sygic-Maps-Eastern-Europe-03.2010-TA New Map
http://www.symbiantalk.net/showthrea...1171#post81171
hi raju,
sorry for d noob question. i am experiencing same problem unable to detect map after launching sygic.
here's what i did :
i have downloaded sygic 10 for android from ur link and malaysia map onto my htc desire.
1. installed the sygic apk file
2. unrar and put in the map (mys.pak) onto sdcard\maps\mys
may i know how do i put in the keygen step by step?
*also i cant find the mlm files!
sorry for d noob question. thanks!
here is my directory structure :
sd\drive
sd\maps
sd\res
sd\maps\mys\mys.pak
sd\maps\wcl\wcl.pak
hi raju can u give mi link to maps for india?
sorry i cant find new to this forum.
Hi Raju, your assistance will be greatly appreciated
I'm trying to install the South African maps, activated it as such
using the mlm:
[zaf]
name=Zuid Afrika
tts=no
sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
speedcam=yes
speedCamRelease=2009.03.05
but still get no maps found
Thanks in advance
PS
If I edit and say
speedcam=no
maps=TA:mys:2009.03
activation doesn't work
Help please
