Page 2 of 11 FirstFirst 12345 ... LastLast
Results 11 to 20 of 108
Thread: MODES for Cooking Firmware
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    Default Re: MODES for Cooking firmware
    FOR THOSE WHO ARE SEARCHING FOR COOL STARTUP BOOTSCREENS FOR THERE CFW
    Pls check here=-
    http://www.symbiantalk.net/showthrea...-By-Ravish_919
    JOIN FOR FREE ONLINE CLOUD/STORAGE:
    DROPBOX (max. upto 18GB.)-
    2GB.+500MB. Bonus
    MINUS.com (max. upto 60GB.)-10GB.+1GB. Bonus
    Join before its too late...
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    -=TRY THIS AT UR OWN RISK=-
    Edit rofs3 file for the best results of ur cfw.
    Do not limit ur skills to rofs2.
    2GB.+500MB. Bonus
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    Here is the mod to add more symbols to text in ur cfw=-
    check out this thread-http://www.symbiantalk.net/showthrea...d-more-symbols
    only the change is u only got to edit the original file in rom not to copy it c drive.
    U can edit *.rxx file with help of hex editor like resedit . just google "resedit" to download it.
    In rxx file xx stands for any no. from 01 to 99 so dont get confused.
    -=GOOD LUCK=-
    2GB.+500MB. Bonus
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    HERE ARE SOME COOL MENU CIRCLE THAT U CAN USE IN UR CFW=-
    http://www.symbiantalk.net/showthrea...le-S60v3-S60v5
    if u want to create ur own menu circle then use mif creator that is added in the first attachment.
    it just converts image files to mif formatt ( better to use *.png file to convert to mif formatt as pngs can be created with transparent backgrounds )
    2GB.+500MB. Bonus
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    nice work bro
    [Font Master]
    STalk Logo Contributor
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Ho Chi Minh, Vietnam
    Samsung Galaxy S2 T-Mobile
    Nice tips & tricks,
    Let's me try later.
    Thanks a lot
    Goodbye Symbian
    Mar 2010
    Singapore
    N97
    V21
    Quote Originally Posted by Nitindeck View Post
    Change Bluetooth file transfer directory=-
    There's a file "10204DAB.txt" in
    Private\10202be9\
    Change the value E:\received to
    whatever u want.
    Here is the modified file-
    http://uploaded.to/file/qlm52g
    one question,originally mine is "0x6 int 163" whereas urs is "0x6 int 110",do i have to change the value of the int?or just change the string?
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    HERE IS THE MOD TO DISABLE VIBRATION DURING LOCK/UNLOCK=-
    No more annoying vibrations when
    lock/unlock screen with side key and it
    will SAVE YOUR BATTERY!
    - put folder 10282BC4 in your rofs2/
    Private/ and enjoy. TubeActivity.rul
    will replace original and be placed in
    Z:/
    This folder in .core contain many rules,
    if someone want to change other
    rules, copy within x-plore from Z:/ and
    edit.
    We can change all files in core, in this
    way, so go on work!
    DOWNLOAD
    uploaded.to/file/3vhrizuploaded.to/file/3vhriz
    2GB.+500MB. Bonus
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    Quote Originally Posted by zq9250 View Post
    u got to change the whole string or could replace mine one with ur file.
    2GB.+500MB. Bonus
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    MOD TO INTEGRATE ROM PATCHER PERMANENTALY TO ROM=-
    Guys to be able to have rompatcher
    fully working while in z:\
    1) you need to unpack rompatcher.sis
    using siscontents
    2) place ALL files in the right
    directories in z:\
    3) place the attached file in Z:
    \Resource\
    4) repack rofs2 and flash
    5) set patches to auto
    6) reboot
    enjoy
    DOWNLOAD&-
    http://ul.to/zvagpx
    2GB.+500MB. Bonus
