Page 3 of 11 FirstFirst 123456 ... LastLast
Results 21 to 30 of 108
Thread: MODES for Cooking Firmware
  1. #21
    Mar 2010
    Singapore
    N97
    V21
    Default Re: MODES for Cooking firmware
    Quote Originally Posted by Nitindeck View Post
    u got to change the whole string or could replace mine one with ur file.
    so i only need to change the string part,nothing else right?
  2. #22
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    NEW MODES UPDATED=-
    1. All patches.zip - Contains
    all available Rom Patcher patches for
    Nokia 5800
    I placed
    this folder directly on Z drive. Rom
    Patcher works perfectly fine and till
    now I
    faced
    zero reboot problem!
    The file is
    updated. 2 new patches added!!
    2. Java permision mod.zip -
    Look into app manager/
    installed/"your installed Java apps'/
    options, see everything is always
    allowed and no more anoying
    notificatons!
    Mod
    Updated! Download the new file!!
    3. Widget security disable Mod.zip -
    Use this Mod to disable annoying
    security warnings while opening
    widgets
    INFO:The Mod is updated and works fine now.
    -=DOWNLOAD=-
    http://ul.to/1yt7br
    (THANKS TO GOC FOR UPDATE)
    JOIN FOR FREE ONLINE CLOUD/STORAGE:
    DROPBOX (max. upto 18GB.)-
    2GB.+500MB. Bonus
    MINUS.com (max. upto 60GB.)-10GB.+1GB. Bonus
    Join before its too late...
  3. #23
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    CONTINUING MY FIRST (i dont added this to my first post coz this gonna create mess there)
    NEW MODES=-
    26. File Transfer Mod.zip - Place this
    file in given location to get all received
    files directly on E:/Received. Don't
    forget to create the folder
    "Received" in your MMC. Or you may
    edit the file as you like
    private/10202be9
    27. Multi Mod.zip - IMPORTANT: This
    mod is an updated and combined
    version of Mods No.15 and No. 19
    Use this Mod instead
    of No.15 and No.19 Mods
    Place the two files in
    given location and get these results:
    1. RomPatcher
    Autostart
    2. No Nokia SMS
    sending after hard reset or flash
    3. Fast Boot up
    (Optimized for speed)
    4. More free RAM on
    startup (I got 70.12 MB)
    resource
    Note: Remove
    welcome2.exe from rofs2/sys/bin if it's
    there. I did't like the idea of a dead
    "Phone
    Setup"
    icon on menu. The Nokia Welcome or
    Phone Setup application in menu will
    work....only it
    will not
    autostart and send sms automatically
    after a hard reset or a flash. I did this
    so that you
    can
    use the "Phone Setup" application if
    you need later..
    28. Lock Unlock Mod.zip - No more
    vibrations now when lock unlock
    screen with side key even when
    vibrations are turned on in
    profiles
    (Thanks to GOC)
    private/10282BC4
    ********************************************UPDATE #5***********************
    29. Improved Camera Sound Mod.zip -
    Use this mod to remove camera beep
    (taking photos and video) when
    warning tones in profiles
    are ON!!!
    for details
    30. SmartSIS.zip -
    Anyone having problem with MIF
    Maker, use this software to convert
    JPEG or SVG to MIF
    INFO:
    Requires Python 1.4.5 to run.
    31. Improved Caching Mod.zip -
    This mod is an updated version of
    No.3 Mod.Use this Mod instead of
    mod No.3
    Place
    files in given location for improved
    caching on all drives
    ********************************************UPDATE #6***********************
    32. Heap Size Mod.zip - This Mod
    Increases System Memory Heap Size
    and decreases Application Delay and
    Close Time
    rofs2/private/10202D56
    33. Camera mute Mod - Another
    alternative to mute the camera sound
    even when warning tones are ON!
    (Stick to "Camera
    1" as camera capture tone)
    system/
    (thanks naughtypope)
    33. Information: Tips for changing
    default ringtone:
    1. Either use mod No.4
    supplied here and then edit the file to
    target to your ringtone file
    2. Or convert your
    favourite to "aac" format and place in
    rofs2/data/sounds/digital and rename
    it as "Nokia tune.aac"
    3. If you want Gasolina
    as default use "Gasolina.zip" and
    place files in rofs2/data/sounds/digital
    (Thx naughtypope)
    ********************************************UPDATE #7***********************
    34. Fixed HS.zip Get 5
    Homescreens for Nokia 5800
    1. Contacts Bar
    2. Full Page (6
    icons)
    3. Finger Use (8
    icons)
    4. Navigation Bar
    (Satio)
    5. Omnia HD
    (Basic)
    35. AIO Homescreens - 5 Homescreens
    for Nokia 5800
    Use either this Mod
    or Mod No. 34
    ********************************************UPDATE #8***********************
    36. BT Name Mod.zip - Edit this file
    and change the default Bluetooth
    name "Nokia 5800 XpressMusic" any
    name of your choice!
    Change it and see...
    private/100069CC
    37. Open Apps.zip - Pressing and
    holding the menu key for sometime
    opens up the Open Applications
    Dialog.
    Edit this file to
    change "Open Applications:" text to
    any test of your choice. Be carefull,
    use 18 leters only!
    resource
    Note: Look Lines
    "6db0" and "6dca" using Hex Editor
    and change!! Best of Luck!!
    38. Sensor Mod.zip - This mod is an
    upgrage to default sensor controls of
    Nokia 5800.
    After applying this
    mod open sensor settings and see. By
    using this mod you will be able to
    silence
    calls and
    snooze alarms just by shaking your
    phone[/b]
    Use this mod as directed in the zip file.
    39. Multi Mod Refined.zip - For better
    performance and RAM the voice
    commands and some less used
    processes were
    dissabled in
    many CFWs available out here. It's
    also done in Mod No. 27 (Multi Mod).
    But If anyone
    wants Voice Commands back in action
    then use this mod. But remember you
    will
    have to
    compromise with your RAM. All
    functions of (Multi Mod.zip) will also
    be available in this Mod. The
    only change is
    that Voice Commands will work. .
    rofs2/resource
    40. Copy Mod.zip - Edit this file
    to determine which files are copied
    from Z drive to C drive after Hard reset
    or flash.
    You can also add
    your own folders in this file which will
    be automically created after
    hardreset.
    This Mod can
    also be used to improve free space on
    C drive
    If Mod No. 14
    dosen't work for you. use this Mod
    instead
    Hey guys, Just let you guys know the
    mod #7 and #27 are buggy on N97.
    Yes it will increase boot up RAM, But,
    the favorite contact I & II won't be
    able to use it on homescreen. Also,
    you CAN'T soft or hard reset!
    (THX aznboix)
    -=DOWNLOAD=-
    http://ul.to/fp1tlj
    AIO HOMESREEN DOWNLOAD HAS NOT BEEN ADDED TO ABOVE ATTACHEMENT SO SEARCH FOR IT IN FORUM
    2GB.+500MB. Bonus
  4. #24
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    [MOD] Disable OVI Contacts in CFW=-
    Extract the archive and copy the
    oviimps_pbkkplugin.dl file to rofs2\sys
    \bin. Then, edit the rofs2\private
    \10202be9\101F8847.txt file and add
    the 2001a94c UID to the 0x8 line, like
    this (you may or may not have the
    same uids on that line, don't worry
    about that):
    cenrep
    version 1
    [owner]
    0x101F4CD2
    [defaultmeta]
    0
    [platsec]
    cap_rd=alwayspass
    cap_wr=alwayspass
    [Main]
    0x1 int 0 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x2 int 0 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x3 string "" 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x4 int 0 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x5 int 0 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x6 string "0" 0 cap_rd=alwayspass
    cap_wr=alwaysfail
    0x7 int 0 0 cap_rd=alwayspass
    cap_wr=alwayspass
    0x8 string "2001AE70,2001A94C"
    16777216 cap_rd=alwayspass
    cap_wr=WriteDeviceData
    0xa string
    "100058f5,10201af2,101f8555,101f8543,101f6de4,1028 2480,101f8512,101f8668,1000
    0xb string "0" 16777216
    cap_rd=alwayspass
    0xc string "0" 0 cap_rd=alwayspass
    0xD int 0 16777216
    cap_rd=alwayspass
    -=DOWNLOAD=-
    http://ul.to/w0ekip
    2GB.+500MB. Bonus
  5. #25
    Excellent Poster
    USA
    HTC HD2 Runnymede v1.3 Team Blue Droid
    Good job bro! Applicable for N97?
  6. #26
    ramisumi's Avatar
    Oct 2009
    Nokia N8 Belle Refresh 111.40.1511 by The One N8 v5.4.0(05-10-12)
    Quote Originally Posted by earthworm1102 View Post
    Most of the Mods posted here for only 5800, I tested myself, But poster haven't mentioned it.
  7. #27
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    Quote Originally Posted by ramisumi View Post
    Nearly all the modes works on n97 those which dont works or r buggy on n97 r stated in the end of the post like the one starter mod.
    AND IF ANY OTHER DONT WORK THEN PLS STATE WHICH OF THESE NOT WORKING ON N97
    2GB.+500MB. Bonus
  8. #28
    ramisumi's Avatar
    Oct 2009
    MOD TO INTEGRATE ROM PATCHER PERMANENTALY TO ROM=-
    Guys to be able to have rompatcher
    fully working while in z:\
    1) you need to unpack rompatcher.sis
    using siscontents
    2) place ALL files in the right
    directories in z:\
    3) place the attached file in Z:
    \Resource\
    4) repack rofs2 and flash
    5) set patches to auto
    6) reboot
    enjoy
    DOWNLOAD&-
    http://ul.to/zvagpx
    Is this working with N97 without any bugs? And 1st 5th and 8th? I have both 5800xm and N97 to test myself, I don't rely on others for that.
  9. #29
    Nitindeck's Avatar
    Nov 2009
    MPT
    Latest
    thanks bro this gonna help all n97 users here
    2GB.+500MB. Bonus
  10. #30
    ramisumi's Avatar
    Oct 2009
    Rep++ for your positive reply bro.
