Your alert file in NDrive folder is wrong. What is the size? If 5k, not good. And look at after import. If size don't change, that is the trouble. The program not add the datas. In latest version and 9.3.14 also, this file is wrong, if you have new install not update. If update from older version, maybe working. Copy this alert file to the NDrive folder, replace what is there: http://anonym.to/?http://www.megaupload.com/?d=Q6A6P55Y After you import gbr.kml again the camera will shown and voice alert will working. Check the file size after import. If change, everything is ok. You will see not policeman symbol, but mini camera icon.
