Results 1 to 1 of 1
Thread: DrJukka's Fake Calls v1.05 S60v3v5 SymbianOS9.x Unsigned {Make Fake incoming Calls}
    Ex-Admin
    Oct 2009
    Indiyaah!
    Fake Calls is an application which with you can fake incoming phone calls, no actual call is made thus the calls are free of charge. All parts of the application are using device themes, thus the Fake Calls Display also shows the native looking UI that uses the currently selected theme.
    Also ringtones used with the Fake calls display are fetched from the device settings. If the contact selected for the Fake Call is having own ringtone, it will be used just as with native incoming call, and if it does not then the current profiles ringtone is used.
    Also if the selected contact has an image or thumbnail picture, they will be shown in the Fake call Display.
    Note that if you don't want to receive any actual calls while using the Fake calls, you can turn your device Offline, and if you do so, please add the Operator name & Fallback ringtone from the Settings, otherwise you will not have the operator name shown, as well as the ringtone will not be played.
    Known issues with current version :
    - Works only with touch devices such as N97, 5800 etc
    - Some gradient transparency effects are not used with the called details bubble in fake calls display
    - BeepOnce for ringtone type in profiles is handled just as RingingOnce ringtone type - Video Ringtones are not shown
    Changelog:
    - Fake Calls updated with Spanish Language, also now 3rd ed FP1 and FP2 devices are also supported.
    Note: The unsigned version works with 3rd FP1/FP2 devices, but not 3rd non-feature pack devices, i.e devices with OS 9.1 such as N73, N80, N93 etc. The 3rd version is also alpha quality, thus do provide feedback on issues you have with it. The looks with is also are not as goof as with touch version, due the fact that the looks differ greatly between different devices as well as device settings
    Attached Files Attached Files
    Visit HERE before requesting for Cert and Key File.
    Visit HERE For Latest & Beautifull Themes 4 All Symbian Devices
    Follow my Updates at twitter @
    abhishekj
