POIAlert v1.61 Speed Camera Pack Cracked by N0ePDA
POIAlert 1.61 for Java description
POIAlert indicates so called POIs (Points of Interest) by voice and display output. A POI can be any point with known GPS coordinates (danger place, restaurant, gas station etc.).
POI data can be loaded e.g. from several Internet sources. At present especially red light and speed cameras are supported.
At first POI data are imported from a file into an internal database (RecordStore). At runtime POIAlert loads all POIs within a radius of 5 km into a cache. During a journey the cache is being updated automatically. The current position is permanently compared with the positions of the cached POIs. This comparison depends on the current speed. As soon as the GPS receiver is near a POI, a voice and an optical information will be given. Since the voice output may be quiet depending on the type of the mobile phone, a hands-free speaking system or headset are recommended.
POIAlert runs on all phones which support at least CLDC 1.1 and MIDP 2.0 and allow access to Bluetooth (JSR 82) or the serial interface (data cable) and to the local file system (JSR 75). That applies to nearly all current mobile phone models. POIAlert requires significantly more CPU power than the other applications on this website. Since reliable comparisons of the CPU power of the several mobile phone types are not available, it is necessary to test POIAlert on the desired phone. Among others POIAlert has been tested successfully with the Nokia devices 6110, 6131, 6288, N73, N82, and N95. But a Siemens S65 is so slow that it can be used only with a small number of POIs.
GPS receivers with Bluetooth or serial interface are supported, which provide the NMEA 0183 sentences GGA and VTG or RMC. That nearly all at the market available might be. In the connection mode "Network/Internal" the Location API (JSR 179) is used. In this case no external GPS receiver is needed. The location is determined by the internal GPS receiver or by the network provider. The latter is obviously supported however in Germany so far by no provider.
N0ePDA Speed Camera Pack includes many Speed Camera Files for several countries!
Here the List:
Please read .nfo file for instructions!
