Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: Nokia X6 Hack FW v20.0.005 PNHT Method
    May 2010
    UK
    N8-00
    The N8 Remix for Belle CFW by me :)
    Default Re: Nokia X6 Hack FW v20.0.005 PNHT Method
    It's ok...must've done something wrong as i've since been able to install a couple of unsigned apps
    Thanks again
    Jun 2010
    United Kingdom
    Nokia X6
    Hi,
    i'm new to all this,
    how exactly do i hack my X6 so i can run unassigned applications on my phone?? i have firmware 20.0.005
    Jun 2010
    USA
    Nokia X6
    what about about if I have rm-551 instead of 559 and it is a US unlocked version.
    Quote Originally Posted by akbisw View Post
    then you have to edit your firmware your self. Go here you will know how to do it http://www.symbiantalk.net/showthrea...V30.009-Hacked
    SymbianTalk Helper
    chandarakk's Avatar
    Dec 2009
    cambodia
    N95 8G V35 E51V410
    E51 V410 HACK BY MY OWN FILE
    or if u dont know what to do just upload ur uda file here
    Jun 2010
    Australia
    Nokia X6
    Hi
    Once Jaf is open i select manual flash and dead USB.
    When i attempt to select INI. It tells me the following
    Searching for default location of ini...
    Checking path: \Products\\
    Searching for JAF saved location of ini...
    Checking path: *.vpl\
    No ini files found...
    Could this be due to the fact im running windows 7 64bit ?
    I have seen on other posts the default pathway should be something like c:/program files/common files/something data / nokia / products / ect. ..
    Can anyone shed some light on this
    Cheers
    Quote Originally Posted by Tbaggys View Post
    Hi
    Cheers
    try this tutorial http://www.symbiantalk.net/showthrea...V30.009-Hacked
    Jun 2010
    Australia
    Nokia X6
    Quote Originally Posted by Theone View Post
    Thanks Theone
    I have just flashed my x6 sucessfully.
    All is working well am looking at SPB mobile shell, looks good.
    Thanks once again
    just saw v21 in navifirm but only for 8gb device. any one using 16gb versoin with v21
    David's Avatar
    UK London
    2X>OneX>Nexus4
    Jaf not working for me. Its set my phone to restart then nothing happend?
