Page 14 of 15 FirstFirst ... 41112131415 LastLast
Results 131 to 140 of 141
Thread: Nokia OVI Maps 3.04 For Unsupported FP2 Devices + New Patch System By Somin.n Update [8.8.2010]
  1. #131
    Czech Republic
    N96
    Default Re: Nokia OVI Maps 3.04 For Unsupported FP2 Devices + New Patch System By Somin.n Update [8.8.2010]
    Does anyone have a clue what could be the problem? I´m able to install version 3.01. I will be grateful for any advice.
  2. #132
    Nov 2010
    singapore
    U1
    1224-3789_R2AK006
    SE Satio, can install ovie map??................
  3. #133
    May 2010
    Czech rep.
    Nokia 500
    Anna 010.032
    Hi! Try this:
    http://www.symbiantalk.net/showthread.php?31604-OVI-Maps-v3.04(165)-m0h1t-Mod-For-OmniaHD-And-Satio
    or this:
    http://sonyericsson-vivaz.blogspot.com/2010/05/nokia-ovi-maps-on-vivaz-satio-without.html
  4. #134
    Oct 2010
    Hagenbach, Germany
    Samsung i7110
    hi @all i've got a Samsung GT I7110 Pilot which is also S60v3 used along time v3.01 out of this forum went over to 3.03 but 304 i can't get to work can anybody advise me a bit in the right direction? All i know is that my Phone should be an FP2 device and of course it's hacked so far - is there a sence to update to 304 anyway?
  5. #135
    Jan 2011
    Nokia N79
    changeUID.exe is not running on my pc (xp sp3)!
    btw, anyone got the maps working with N79 firmware 32.001?
    Update: Managed to install successfully using the somin.n method after a lot of tries! thanks so much somin.n
    changeUID.exe not opened in my pc and also tried to create one using the txt method!
    But it showed a red cross icon in rom patcher.
    So, I open the open4all.rmp using notepad and just rplace the last line
    with SnR:sys\bin\hal.dll:64DA002064DA0020:CF4D0120CF4D0 120 ( thanks jmez for knowing)
    and finally it works!
  6. #136
    boncu's Avatar
    Dec 2009
    Grisee, Jawa Timur, Indonesia, 1.10254188994E+14, Grisee, Jawa Timur, Indonesia
    Music Makan Tidur, Teaching Oto Plus, Harry Potter Iron Man 2, Rock Star, 2012 Marilyn Manson, Speed
    i have X5-01
    this phone has no GPS n maps.
    will it working on my device???
    i've try install maps from the OVI Store, n it's doesn't work.
    ----------------------------------------edited----------------------------------------------------
    after i follow all the instruction on first post,
    i succeded install the maps, but can't open.
    i make patch from changeuid.exe n still not working.
  7. #137
    May 2010
    Nokia N79
    Quote Originally Posted by prateekj92 View Post
    ThnX Budovi.......working on N79.....
    Hi Prateekj,
    Can you pls tell me how you have hacked your N79 with HelloOx 2.02. I have tried a lot but is unable to hack mine. Pls tell me procedure.
    Thanks in advance
    --- Update ---
    Quote Originally Posted by mtik View Post
    Hello Mtik,
    guys pls help me in hacking and installing Maps in my N79. I am not able to do. Pls help me.
    Thanks in advace.
    ====================EDITED======================== ======
    After trying lots of time,
    I managed to hack my N79 with HelloOX.
    Maps installed and working at its fullest.
    Thankx guys for your great work. luv u...
  8. #138
    craxyvirux's Avatar
    Feb 2012
    Philippines
    E75
    Default Re: Nokia OVI Maps 3.03 For Unsupported FP2 And FP1 Devices
    whats the password sir?
  9. #139
    craxyvirux's Avatar
    Feb 2012
    Philippines
    E75
    sir im not able to download the file is passwoord protected.. can you send me the password? thank you!
  10. #140
    Sep 2012
    Jordan
    Nokia E75
    can u pls provide me with step by step to install this in E75??
