Page 3 of 15 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 141
Thread: Nokia OVI Maps 3.04 For Unsupported FP2 Devices + New Patch System By Somin.n Update [8.8.2010]
  1. #21
    Oct 2009
    ind
    e75
    Default Re: Nokia OVI Maps 3.04 For Unsupported FP2 Devices
    @The one
    first file not found clean uninstaller one
  2. #22
    Apr 2010
    Slovakia
    E75
    UPDATE [24.5.2010]
    Version 3,04 in one post (for FP2 devices)
    1, 3,04 10wk17_b07 (stable, I think this is the newest version)
    For phones with maps (upgrade):
    http://www.4shared.com/file/9WVm7BN6/maps_mod.html
    For phones without maps (install):
    http://www.4shared.com/file/EZLbDPet/maps_mod_not_installed.html
    Wi-Fi positioning support package:
    http://www.4shared.com/file/89GCqy7_/Wi-Fi_Positioning_support.html
    2, 3,04 10wk01_b05 (beta relase)
    http://www.4shared.com/file/lhVpei-8/maps_mod.html
    For phone without maps (install):
    http://www.4shared.com/file/PszBHcbK/maps_mod_not_installed.html
    http://www.4shared.com/file/TqZzgTqn/Wi-Fi_positioning_support.html
  3. #23
  4. #24
    Oct 2009
    ind
    e75
    is wifi positioning diff for each release?
  5. #25
    Yes wifi pack separate for all release also in suported phone. But orginal installer you get it one sis file.
  6. #26
    May 2010
    Czech rep.
    Nokia 500
    Anna 010.032
    Hi! Here is solution how to install ovi maps 3.04(165) for FP2 devices and ovi maps 3.03 for FP1 devices.
    Tested phones:
    N85, N96, E75, N79, N78, 6220
    1. You need to have hacked phone (maybe format will be required before installing) and latest fw
    2. Need patch for rompatcher, for every model is different!
    ; Change N85 machineUID
    ; by somin.n
    SnR:sys\bin\hal.dll:862D0020862D0020:CF4D0120CF4D0120
    ;Change E75 machineUID
    ;by somin.n
    SnR:sys\bin\hal.dll:9D240020:CF4D0120
    ;Change N96 machineUID
    ;by somin.n
    SnR:sys\bin\hal.dll:822D0020:CF4D0120
    ;Change 6220c machineUID
    ;by somin.n
    SnR:sys\bin\hal.dll:52DA002052DA0020:CF4D0120CF4D0120
    or you can create new one just for your phone in step 4.
    3a. FP2 Installation file: -> this is part of original maps installer, it is not modified and it can be unistalled. It is latest official build.
    http://data4.edisk.cz/stahni/43819/maps.sisx_7.91MB.html
    3b. FP1 Installation file: -> original from nokia
    http://nds1.nokia.com/PRODUCT_METADATA_0/Explore_Services/Ovi_Maps/nokia_maps_3.03_10wk11_b04_s60_3.1_rom.Nocs.sis?intc=ncomexpserv-fw-ilc-bdy-con-na-ncomexpserv-at-9-downloadbuttoninstaller31_221x40
    If you can't install this version, try to remove all previous versions. If it will not help, you need to format your phone (and i suggest format memory card too). Than will be the installation process successful. :good2: After successful installation, you can disable/remove the patch.
    4. How to get patch for your phone:
    - downlod this small app:
    http://www.edisk.cz/stahni/35829/changeUID.exe_43KB.html
    - open it and click on the "MachineUID"
    - it will open page with nokia uid's, there find your phone model and its uid
    - copy the uid (without the 0x) back to the program
    - select FP1 or FP2
    - paste "Go!" button and patches will be save to the app folder
    - it will generate two patches: "changeUID_long.rmp" and "changeUID_short.rmp"
    - first try to apply "changeUID_long.rmp" if you will get red cross in RP try to apply "changeUID_short.rmp"
    If you have successfully installed maps, but you get some errors than you can try install this package S60SOA. This are some additional libraries.
    http://nds2.fds.nokia.com/fdp/interface?fid=A0K95YUXYQRSME
    There is possibility that you can't run this maps on your device, because lots of nokia devices aren't supported and this is way how to "add" you phone to supported list, but it isn't 100%. Just try and you will see if you have happy day.
    Please, if you post here some reply write please your way of installation:
    1. what package did you use for install (maps.sisx OR original from nokia)?
    2. did you format phone AND/OR memory card?
    3. do you have some errors with using maps or something else wrong with phone?
    It is important, so please share!
    Last edited by somin.n; September 13th, 2010 at 10:42 AM. Reason: add support for insalling 3.03 on FP1 devices
  7. #27
    Quote Originally Posted by somin.n View Post
    Hi! Here is other solution how to install ovi maps 3.04(165) for N85 (maybe other FP2 devices too).
    1. First you need to have hacked phone (maybe format will be required before installing)
    2. Need this patch for rompatcher: -> this patch is only for N85, for another models you need to make your own.
    ; by somin.n
    - at first, try to make your own patch and try it in RomPatcher, without the patch, you can't install
    3a. Installation file: -> this is part of original maps installer, it is not modified and it can be unistalled
    3b. You can try to use the original package from nokia, it should works for some models
    http://nds1.nokia.com/phones/files/software/maps_installer_3.04_10wk17_b07_s60_3.2.Nocs.sis?intc=ncomexpserv-fw-ilc-bdy-con-na-ncomexpserveu-g0-9-downloadbuttoninstaller32_221x40
    If you can't install any version, try to remove all previous versions. If it will not help, you need to format your phone. Than will be the installation process successful.
    http://www.edisk.cz/stahni/86911/changeUID.exe_41.5KB.html
    - paste "Generuj" button and patch will be save to the app folder
    I know that this method works on three N85 and it should works on other FP2 devices, please try and say if it works for you on another models.
    thread title changed thanks somin.n
    i will give a try when i am on my pc rep+
  8. #28
    Excellent Poster
    Smith's Avatar
    New york
    Nexus 7, Galaxy Note 2
    v4.1
    ; by somin.n
    big big thanks mate working like charm.
    For those who don't know how to create patch just creat a new text file. Copy patch code past in new text file. Rename new taxt.txt to new taxt.rmp then copy to e:/patches folder.
  9. #29
    Excellent Poster
    Galaxy S2 / XOOM
    ; by somin.n
    thanks for excellent method work with me rep+ mate
  10. #30
    Apr 2010
    Hungary
    Nokia 6220 Classic
    Default Re: Nokia OVI Maps 3.04 For Unsupported FP2 Devices + New Patch System By Somin.n
    Hy!
    On my Nokia 6220 classic (S60v3 FP2) don't work.
    I tried all method:
    1. Installed the maps (try start, don't work), and after I can't installed the maps_mod, because it sayed: Update Error
    2. Installed original Nokia Maps 3.04 (and don't work).
    I made the patch file and loaded after tried install the Ovi Maps 3.04.
    Any can help me?
