Allso, for me searching addresses doesn't work.
That's bad.
Any solution? Will downloading maps using nokia map loader fix this?
That's bad.
Installed as instructed onto my 5800. Downloaded a voice pack, and plugged in an address.... Lo and behold, she spoke to me loud and clear! Went without a hitch.
Thank you!
were is the voices pack ?
Download link for 5 continents
<a href="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.23.112/171.zip" target="_blank">http://static.s2g.gate5.de/map5/mapl...23.112/171.zip</a>
<a href="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.23.112/172.zip" target="_blank">http://static.s2g.gate5.de/map5/mapl...23.112/172.zip</a>
<a href="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.23.112/173.zip" target="_blank">http://static.s2g.gate5.de/map5/mapl...23.112/173.zip</a>
<a href="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.23.112/174.zip" target="_blank">http://static.s2g.gate5.de/map5/mapl...23.112/174.zip</a>
<a href="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.23.112/175.zip" target="_blank">http://static.s2g.gate5.de/map5/mapl...23.112/175.zip</a>
I have the same problem with all versions of nokia maps 3. On the other hand this was not hapening with maps2. I always need to be connected now to search for an adress
here you got it in bb-code again![]()
Can someone tell me the difference with the retail version we have with a new phone ? For example, I've a Nokia 5800 "Gun and black" with nokia map v3.03. How do I know what maps is already installed ? I only need to check my "[memory card]\cities\diskcache\" folder ?
Thank you in advance
No map included with ovi map version. You have to download map and place it to your phone. You can also use nokia map loader
hey bro. can u help me in finding the maps for pakistan?? i'll be really thankful if u find me those. thanks in advance
