Thanks, installed without any problems and runs very smoothly. I'll go drive around and test it later today.
This version have some bug some people only can press # . Try older version http://symbiantalk.net/showthread.php?t=1412 .
I upgrade it working without problem
Previous version much better
Before Start Posting In SymbianTalk.net / Mobilephonetalk.com Read This Rules
Post Your Photo Here & What Is Your Favorite Song Right Now?
If License Verification Require On My Paid Apps/Games Try To Use Latest Lucky Patcher From Here
If You Have Downloading Problem from FileHost / Cyberlockers Post Your Problem Here Or Use Free Downloader Site From Here
Thanks,
Just an FYI for anyone considering trying this on a Nokia E71x...you may want to wait. I installed 3.4.23, only to find that the E71x keyboard isn't supported in this earlier version, either. I was able to type in some letters - but not corresponding to the letters I pressed, however. So, I was able to activate the maps, but not able to type in addresses to navigate.
This looks to have the potential to be a great piece of GPS software...just not for me, yet.
Thanks to Undercode, and to all those who helped.
thanks a lot works like charm on n97 and much more accurate than Garmin.
Yep, drove around today and it really works, actually very well indeed. Big thanks to OP for sharing.
Speed cam locations downloadable somewhere?
EDIT:
I'm glad that I get to answer my own question.
1. If you want speed cam locations to your NDrive, go to http://www.gps-waypoints.net/gps/ and select from the list (Traffic related -> Speedcamera), select your country, and CSV with header as the file format and download.
2. Extract the file to NDrive\speedcams.
3. Run NDrive, go to Menu -> Settings -> Data Import/Export. Select Import Alerts. You should see the extracted file there, click it and let it import the file.
4. You're ready to go driving with newly imported speed cams locations![]()
