Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 68
Thread: NDrive v3.5.18 For Symbian S60v3 S60v5 By Undercode
  1. #21
    Default Re: NDrive v3.5.18 For Symbian S60v3 S60v5 By Undercode
    Quote Originally Posted by puustinen View Post
    Speed cam locations downloadable somewhere?
    EDIT:
    I'm glad that I get to answer my own question.
    1. If you want speed cam locations to your NDrive, go to http://www.gps-waypoints.net/gps/ and select from the list (Traffic related -> Speedcamera), select your country, and CSV with header as the file format and download.
    2. Extract the file to NDrive\speedcams.
    3. Run NDrive, go to Menu -> Settings -> Data Import/Export. Select Import Alerts. You should see the extracted file there, click it and let it import the file.
    4. You're ready to go driving with newly imported speed cams locations
    Thanks rep+ added
  2. #22
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Default NDrive v3.4.23 To 3.5.18 Including Fix For Keyboard Problem
    I know many of you are having problems to type in the serial number on NDrive 3.5.18. So, I have built a patch:
    1) Install NDrive 3.4.23 (no way to install 3.5.18 directly)
    2) Register the product and make sure it works (including maps)
    3) Download the attached patch
    4) Unzip and run lpatch.exe
    5) Point to ndri3.ndr in NDrive/data on the memory card
    6) Download and install undercode's 3.5.18
    7) Done. Run 3.5.18. It won't ask for the serial any more.
    Cheers,
    Attached Files Attached Files
  3. #23
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
  4. #24
    Jun 2009
    Default Re: NDrive v3.4.23 To 3.5.18 Including Fix For Keyboard Problem
    Quote Originally Posted by Raju View Post
    Cheers,
    FYI, using the patch and this method did allow me to install 3.5.18. However, once installed, the keyboard is still non-functional for navigation.
    Thanks for your efforts!
  5. #25
    Jul 2009
    HK
    N8-00
    when Language change to Cantonese, all characters change to "????"
    Is there any fonts for Cantonese?
  6. #26
    Jul 2009
    Finland
    Nokia 5800 XpressMusic
    V 21.0.025 Hacked
    Does NDrive use A-GPS or network based positioning?
  7. #27
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Quote Originally Posted by kivo View Post
    You must install new language / voice files
  8. #28
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    use gps
  9. #29
    Jul 2009
    Finland
    V 21.0.025 Hacked
    use gps
    I meant that does it use ONLY gps or a-gps / network with it?
  10. #30
    Jul 2009
    UK
    Samsung i8910
    I8910XXIG2
    When I install pips_samsung_1_2_SS.sis an update error appears, I have tried installing the main application into the phone memory or memeory card but same error occurs. The program appears to work ok, does anyone know what this file does?
