Page 7 of 7 FirstFirst ... 4567
Results 61 to 68 of 68
Thread: NDrive v3.5.18 For Symbian S60v3 S60v5 By Undercode
  1. #61
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Default Re: NDrive v3.5.18 For Symbian S60v3 S60v5 By Undercode
    try this turkish1: http://www.megaupload.com/?d=JWMGNB3L MelahatTR.zip
    turkish2: http://www.megaupload.com/?d=S04CUNP5 UgurcanTR.zip
  2. #62
    Dec 2009
    turkey
    n97
    v11.0.021
    Thanks
  3. #63
    Jan 2010
    turin
    non funziona pił il link per le mappe italiane
  4. #64
    Azores Islands
    Nokia N97
    Quote Originally Posted by babylellina89 View Post
    Try this one
    After downloading, open the exe with winrar and extract the zip containing the map. Or just run the exe and browse to where you want the zip extracted.
  5. #65
    Jan 2010
    los angeles
    e63
    Default Re: NDrive v3.4.23 To 3.5.18 Including Fix For Keyboard Problem
    cheers for the qwerty patch hopefully itll work, after that Ill attack the ndrive.ini and customise it for the e63 ( no built in gps)
  6. #66
    Jul 2010
    Croatia
    Nokia N97
    v 21.0.102
    Can anyone pls help me? I've installed the Ndrive on my Nokia N97 and the Eastern Europe map. So when i start the Ndrive the maps appering and dont load when i click on the map button. And one more question, how do i activate the maps with the keygen? I didn't see where i can put in the serial in the Ndrive application. Sry 4 my bad english and i hope u guys can help me, cya.
  7. #67
    Team-O's Avatar
    Jul 2010
    Finland
    N96, N80 and N6630
    Quote Originally Posted by slale View Post
    The instructions found from keygen -archive are pretty straight forward. Have you read them?
    1 - After you have installed the program and the map, you use the keygen
    2- Then you start the application and "register" the NDrive (use the serial number generated by the keygen)
    3 - Then you need to "register" the map. NDrive has now a DeviceID (after step 1), add that to keygen. Then you add MAP ID (for example TA-EUR-SCANDI-*-2009.02)
    4- The keygen creates 4 activation numbers, at least one of them should work in order to unlock the map.
    5 - Enjoy
    Please guys, correct me if I made mistakes.
    For some reason, I had difficulties with version 3.5.18. So I installed v3.5.15 instead, That version works great in my N96.
    Regards,
    Team-O
    PS. There is nothing wrong with your english. As far as we can understand you, your english is good (applies to everybody). I think that most of the members are NON-NATIVE english speakers.
  8. #68
    Oct 2011
    canada
    nokia 5230
    Hi.
    I have registered my ndrive by entering sr no from keygen and sucessfully registered but it did not gave any device ID.where i can find this device ID? Appreciate your help.
