Results 1 to 8 of 8
Thread: 5233 BEST Modded Firmware V21 (By arunorvic)
    ♠ The Administrator ♠
    Feb 2010
    Multan,PAKISTAN
    [HTC One X ,Iphone 3GS, HTC Explorer]
    HTC One X 4.0.4 Rooted,Iphone 3GS IOS 5.1.1 Jailbreaked with Redsn0w , HTC Explorer Rooted]
    Note:- arunorvic, I am not the creator of this firmware,Its just that i use nokia 5233 and since its custom firmware is not listed here on this site so i thought posting here would help other 5233 users,so all the credit goes to the person who developed this modded firmware!
    BASED ON LATEST NOKIA FIRMWARE V21.1.004
    I WORKED VERY HARD FOR THIS SO PLZ POST COMMENTS AFTER USE
    █☻_AOV MEGA MOD 21.1.004 N-5233 FIRMWARE_☻█
    AOV MEGA MOD 21.1.004 FIRMWARE (BASED ON LATEST NOKIA V21.1.004)
    100% MODDED BY ARUN.OR.VIC
    NO ONE CAN BEAT THIS MOD , IT HAS 7 COOLEST HOME SCREEN THEMES IN-BUILT.
    NEW AOV MEGA MOD MADE 100% BY ARUN.OR.VIC IT HAS ALL THE POSSIBLE TWEAKS AND MAX POSSIBLE SPEED , WITH INCREASED CAM QUALITY , NEW IMPROVED FILE MANAGER , NEW SPALSH SCREEN , NEW BOOT SCREEN , HUGE LIST OF MODS N TWEAKS , SUPER SMOOTH MENU EFFECTS AND MUCH MORE IN OTHER WORD BEST N LATEST MOD FOR NOKIA 5233.BEST OF BEST IT HAS BEST THEMES IN THE TOWN INBUILT IN IT.WITH ALL NON NEEDED TRASH REMOVED TO GET EXTRA SPEED AND SPACE.
    FULL CHANGELOG FULL CHANGELOG FULL CHANGELOG
    AOV MEGA 21.1.004 FIRMWARE
    AOV MEGA MOD 21.1 Nothing Can Beat This.........
    LATEST CONFIGURATIONS:
    -Increased device's FPS from 22 to 60
    -Highly Increased Application/Gaming frame rates
    -Increased Response Rate (Now touchscreen will be more responsive)
    -Music Player response highly increased (Instantly pauses/plays on clicking the buttons)
    -Reduced effects complexity which should result in a speed increase
    -Increased Heap Size further to boost up performance
    -Lags in Menu and Other Large Applications removed
    -Polished the UI for heavy usage
    -100% Bug Free Version
    -Phone will never slow down and the RAM won't be decreasing (RAM Caching modded)
    -80MB on C:\ (Phone memory)(Use Empty UDA File Supplied)
    -Average RAM Increased
    -Smoother Kinetic Scrolling
    -Many more Performance Upgrades
    -Increased maximum CPU time
    - MORE......
    MODIFICATIONS:
    - Nokia SMS Sending (My Nokia) Disabled
    - Default bluetooth name: ArunOrVic
    - Number of message sent saved increase from 20 to 999 by default
    - OVI Contacts totally disabled
    - Now you can record up to 12 Hours
    - Voice recording during call fixed
    - RAM Cache in C:\ for better performance
    - Browser Cache increased to 10MB and moved to E:\
    - Super Fast Screen Rotation
    - CPU load decreased (Get a very fast phone)
    - Disabled lock/unlock vibration
    - Disabled keypad lights
    - Kinetic Scrolling diabled in short lists
    - Disabled My Nokia Service
    - Zero start up of background applications
    - Auto optimization of RAM cache for keeping up your phone faster even after heavy usage
    - Blank UDA supplied to get highest possible free space on C:\
    - Default theme set to "Living"
    - Lags in Menu removed. The Kinetic Scrolling is optimized (It is no very fast not very slow)
    - Default Fonts Used
    7 OF THE BEST HOMESCREENS ADDED (Built-in):
    1> Vodafone (DEFAULT)
    - Transparent Header and Footer with Frames
    - Nokia Icons
    - Rearranged Right Pane with only usefull links
    - Vodafone icons replaced with OVI/Nokia Icons
    2> Orange HS
    3> Finger Use
    - Four changeable shortcuts + Omnia HS
    4> Full Page
    - Six Icons available with Bottom Bar Shortcuts
    5> Contacts Bar
    - Default Nokia HS
    6> Navigation bar
    7> Contacts bar
    GRAPHICAL PERSONALISATIONS:
    - Original Nokia Shutdownscreen
    - Modified Cool Splashscreen
    - Cool Burp Apple Bootscreen
    - Default Nokia Menu
    - Bootscreen volume set to: 7.0
    - Light Intensity set to 75% light by default
    - Theme Effects: Glide Or Speedy Or SpinSlide
    INSTALLATION FEATURES:
    - SwiPolicy changed which enable to install almost apps without RomPatcher patch (Works 99%)
    - Removed annoying widget security warnings
    - Java permission is set to default
    BROWSER:
    - Nokia Default Internet Browser can go landscape with turning control OFF
    - Some Important Bookmarks edited
    - Cache moved to E:\ and increased to 10MB
    FILE MANAGER:
    - A Cool And Most Powerfull File Manager Added (Latest Version)
    - Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
    - Nokia default file browser will show system folders and root folder (Just enable ReadCroot.rmp Patch)
    CAMERA :
    - Camera Quality Is More
    - Camera will not leave in background after close it (SAVES RAM)
    MUSIC PLAYER AND GALLERY:
    - Music Player Reads only E:\Sounds\My Music\
    - Music player speed highly accelerated
    - Refresh faster
    - Gallery Improved to find files
    MENU:
    - All Laggs in Menu removed
    - Optimized to run very fast and smooth (Tweaked KS in Menu)
    THEMES:
    - Living (DEFAULT)
    - Default Themes RED & BLUE
    - Mini I-PAD THEME
    - Nokia N Series Theme
    APPLICATIONS:
    - RomPatcher+ (Removed Startup Note)
    - File Browser
    FIRST BOOT OPTIMIZATIONS:
    - FOTA reserved spaces in C: deleted: gain 5MB (TOTAL 80 MB FREE NOW)
    - Autocretion of folders
    - Cache folders in E:\
    I HAVE WORKED VERY VERY HARD FOR THIS MOD SO PLZ POST YOUR COMMENTS AFTER USING.
    NOTE NOTE NOTE
    NOTE NOTE NOTE
    PLEASE READ THE TEXT FILE INSIDE
    DO THESE STEPS BEFORE UPGRADE FORMAT MMC
    OR
    BEFORE FLASHING YOUR PHONE CONNECT IT TO MASS STORAGE MODE AND DELETE SYS,SYSTEM,PRIVATE AND RESOURCE FOLDER FROM MMC
    RESET YOUR PHONE BY DIALING *#7370# , PASSWORD = 12345
    ENABLE THEME EFFECTS AFTER UPGRADE. (GO TO SETTINGS ETC ETC)
    IF U DNT PLAY THAT ROLLECTCOASTER GAME UNINSTALL IT.
    FOR 1st Hour Firmware Will Be LiL Slow , DNT WRRY , JUST ON/OFF AFTER 1 HOUR OF USAGE , IT WILL BECOME SUPER FAST...........
    DOWNLOAD THE ORIGINAL FIRMWARE FILES FIRST THIS TIME I HAVE PACKED ALL 8 ORIGINAL FILES IN ONE PACK TO DECREASE THE CONFUSION AND SIZE Wink
    NOKIA 5233 ORIGINAL FIRMWARE V 21.1.004
    DOWNLOAD DOWNLOAD DOWNLOAD
    AOV MEGA MOD V 21.1.004 IS AVAILABLE IN 3 DIFFERENT EFFECT VARIANTS
    Smiley Smiley Links Updated , Music Player Bug Removed , Enjoy Wink Smiley Smiley
    AOV MEGA MOD v21.1.004 (SPIN)
    AOV MEGA MOD v21.1.004 (SPEEDY)
    AOV MEGA MOD v21.1.004 (GLIDE)
    Last edited by ramisumi; July 11th, 2010 at 10:05 AM. Reason: With due respect to creator
    {★★★ Android N00B Guide ★★★}
    {Root Your Phone}
    Share your Pics captured by your Phone's Camera Here
    http://www.symbiantalk.net/signaturepics/sigpic33666_1.gif
    Jul 2010
    Nokia 5233
    AOV MEGA MOD V21 MADE BY ME
    Default Re: 5233 BEST Modded Firmware V21
    this is my firmware guys i created it . Originally its here on my site with updates
    my name is arunorvic so please include this above
    NOKIA 5233 USERS MUST VISIT (GOOGLE MY NAME ArunOrVic)
    Jul 2010
    Nokia 5233
    Default Re: 5233 BEST Modded Firmware V21 (By arunorvic)
    bjroks93's Avatar
    May 2010
    Nokia 5233
    21.4.001 H4CK3D BY PNHT
    did not work for me so i had to create my own firmware but rep+ for ur hard work....
    Jul 2010
    Nokia 5233
    Quote Originally Posted by bjroks93 View Post
    What Are You Saying My Bro , Mega Mod V22 Works 101% Fine And Faster Thn Any Other Firmware , Its Used By 1000's of users worldwide. You Can Check On My site
    bjroks93's Avatar
    May 2010
    Nokia 5233
    Quote Originally Posted by arunorvic View Post
    What Are You Saying My Bro , Mega Mod V22 Works 101% Fine And Faster Thn Any Other Firmware , Its Used By 1000's of users worldwide. You Can Check On My site WWW.N5233.TK
    no i flashed my phone with jaf as it on ur site but when jaf says pooling the phone after that it does not start.....
    Jun 2010
    INDIA
    NOKIA 5233
    bjrocks93 you dont no to use it i have install it and works 100% aov mega mod
  8. #8
    Jul 2010
    Philippines
    Nokia X6-00 16GB Black
    X6^C6 Remix RM-559 v31.0.004
    dead links for the aov mods :c can post another link?
