Page 3 of 19 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 181
Thread: Hack Newest Firmwares N97, 5730, E75, N86 Etc
  1. #21
    Default Re: #HOT# Hack Newest Firmwares N97, 5730, E75, N86 Etc
    Quote Originally Posted by rbaa View Post
    i did it.i tried it in my n86 first it doesn't work.because we should not apply changeswipolicypath.
    onyly instllserver and open4all must be applied.
    No need to aply wipolicypath patch. Only apply installserver patch and open4all that all ur phone now hacked.
  2. #22
    cloud596's Avatar
    May 2009
    INDONESIA
    N86 8MP v21 , N95 v35, N78 v30 ,N97 v21 ( ALL HACKED ), N900 , Samsung Galaxy S2
    V 30.009 ,V 30.0.14, V35.0.01 , V 21.0.105 , PR 1.3.1 CE , 2.3.6 checkrom RevoHD
    Should be work on neweat firmware. Follow the instruction step by step.
  3. #23
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    ROMPatcher with WORKING Autostart attached. Just copy yout patches into E:\Patches
    If you have a FP1 device like my E71 with 300.21.012 the installserver.exe from this hack doesn't work! Also attached a working one.
    You don't need the swipolicy.ini patch on these devices!
    1. Install the hack as described in post #1 and activate open4all patch
    2. Copy my attached installserver.exe to c:\sys\bin
    3. install my attached ROMPatcher over the one from the hack - autostart will work again
    Download installserver - http://symbiantalk.net/attachment.ph...5&d=1248444197
    Download ROMPatcher 1.0.0 - http://symbiantalk.net/attachment.ph...6&d=1248444217
  4. #24
    Jun 2009
    Sri Lanka
    Hacked NOKIA N86 8MP
    21.006 v9.0
    work perfectly on Nokia N86 v11.043
  5. #25
    Jul 2009
    Indonesia
    Nokia 5730 XpressMusic (nokia 5730s-1)
    100.48.122 hacked ^^
    hi all, I need a hand over here. . .
    I have Nokia 5730 Xpressmusic, with 100.48.122 firmware.
    The problem is,
    I can't sign the rompatcher & mapdrive.
    I tried signsis and use it with my cert & key which I got from opda, it said succeed or something like that when the signing process ended, but still, I get the certificate error message when I try to install them.
    I also tried Rootsign & Freesigner, but the result still the same.
    Any advice would be appreciated.
    Thanks in advance.
  6. #26
    Quote Originally Posted by Damz View Post
    The problem is,
    Thanks in advance.
    Ur certificate working with other application?
  7. #27
    Jul 2009
    Indonesia
    I've found the way to sign those files.
    I installed them and follow all the steps mentioned.
    But when I try to install both signed & unsigned game with sisx/sis/n-gage extension, it says file corrupted.
    So now, I can't install anything.
    Does anybody have any advice?
  8. #28
    Jul 2009
    Indonesia
    Yes theone, my cert with any apps.
    it's just the signer. After I use binpda's signsis, I can install it
  9. #29
    Jul 2009
    Indonesia
    I solved it! The problem is caused by changeswipolicypath. If I apply it, It will set the device to give file corrupted stats to d software.
    In other words, after I disable it, the hack works! cheers
  10. #30
