NaviFirm V0.3 A tool for obtaining firmware, product codes & more
NAVIFIRM is the ultimate all-purpose tool for downloading Nokia firmware images, obtaining lists of product codes, and finding the right product code for your phone. NAVIFIRM downloads all this straight from Nokia's servers so you don't have to wait for people to post data packages and lists of product codes.
NAVIFIRM is useful for just about anyone:
End users: Find product codes to use with NSS/NSU
Journalists: Be the first to know when new firmware hits NSU
Developers: Download ROM images for extracting files
Care Suite/Phoenix/box users: Download ROM images to flash
Additional NSU servers can be added by editing Main.cs in the source code.
To use NAVIFIRM, just start navifirm.exe and drill down from left to right. To download files, check the boxes of the files you want (or click the All button), then click "Download from FiRe". Find a directory to put the files in, then click OK. Care Suite and Phoenix should be able to pick up the firmware files if you put them in C:\Program Files\Common Files\Nokia\DataPackage (if you use Vista w/ UAC, you'll have to right-click navifirm.exe and select Run as Administrator). Note that calibration and most other non-firmware files ordinarily included in data packages cannot be downloaded via this tool. To generate a product code list suitable for forum posts, etc., select a product and release, then click the Export PC List button. From there, you can copy and paste the list of product codes or save it as a file.
This software is released with no warranty whatsoever, express or implied. If you screw up your phone trying to flash something downloaded with this tool, it definitely isn't my fault. As bricking a phone is easy, proceed with great caution. You have been warned.
After A long Time , The new Version Of NaviFirm That has been Developed By My Friend (Mohsen-Unique) ReleaseD.
There Are Many New & Handy Features.The Changelog:
NaviFirm V0.3 (Name Of The Program maybe Will Change to :Unique Mobilestan Firmware Downloader UMFD- In the Future Releases)
- Added Maximizing Feature to the whole window
- Added word Serach box under Products & Variants Windows
- Added Capability To copu URL in Download With IDM window
- Added Capability To download Firmware Files With Internet Download Manager IDM
The program may havebugs, Please test it and post the bugs for future releases.
So if you have any suggestion for new Versions , Give them to me in this topic
