Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: Sygic Mobile Maps 10 v8.14
    Jul 2010
    uk
    htc
    Re: Sygic Mobile Maps 10 v8.14
    only way to actived press remind me later option then go to the settings then switch map option then choose your old map mlm file thats all. your done (i done it and it works) blast
    Jul 2010
    indonesia
    6220c
    Default Re: Sygic Mobile Maps 10 v8.14
    SMM10 Malaysia.mlm
    [PRODUCT:SMM10 Malaysia]
    name=SMM10 Malaysia
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    maps=TA:MYS:2009.03
    SMM10 Singapore.mlm
    [PRODUCT:SMM10 Singapore]
    name=SMM10 Singapore
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    maps=TA:SGP:2009.03
    The MLM format above works for my WinMo phone (HTC Touch Pro). before i had the no map-but-already-registered problem, but now it works 100%..
    I also tried to install it to my Android on Touch Pro (XDANDROID) on the same phone using the setupAndroid.APK & the map are as accessible as in WinMo.
    HOWEVER..
    when i tried it in my S60v3 (nokia 6220c)
    before i tried the above method (using 1 by 1 mlm files & new format for mlm) the problem that i have are that the number from the keygen always wrong. I can't get it registered. I tried the method above but i still failed.
    When i go back to sygic MM9, using the same keygen, device ID & the same map (PAK) files, i can register it with no problem.
    Can somebody help me?
    [edit]
    i confirm that the problem is in my 8GB MicroSDHC.
    I tried installing these files to my 6220c on my 1GB spare MicroSD, & it CAN install with no problems.
    It seems that the device ID seemed different when using a large (SDHC) card. the keygen always generate wrong code with that device ID. Can anybody confirm this?
    Banned
    Aug 2009
    Kerala, India
    Nokia N8-00 Hacked
    024.001.C06.01
    Quote Originally Posted by b0z0k View Post
    I have the same problem. I am using 8GB micro SDHC on N82
    Jul 2010
    indonesia
    6220c
    Quote Originally Posted by spknair View Post
    Yeah.. It seems that the 8GB SD card is the culprit. I tried the 8GB card on my WinMo & it gave the same Device ID (it seems that the device ID are generated from the SD/ MicroSD card -- the phone does not change the Device ID). Because of the same non functional device ID, i can't register & i can't use it.
    Tried the 2GB card from my WinMo to my Symbian phone & it works like a charm.
    The device ID generated from that same 8GB card works with the keygen in My Sygic MM9 rel. 7.71. It is completely identical device ID but the keygen works in MM9. I think that somehow Sygic 10 use different method for activation key on SDHC card -- thus making the keygen non functional for SDHC cards.
    So my conclusion is :
    a) 1 & 2GB card works fine with the keygen on all OS (WinMo, Symbian, or Android)
    b) i havent tried 4GB & 16 GB card, if it is SDHC perhaps it doesn't work too (need confirmation)
    c) 8 GB card DONT work with keygen on all OS (WinMo, Symbian, or Android)
    d) Device ID are unique to the SD / MicroSD card, so the OS & IMEI of the phone doesn't affect the device ID & the activation key from the keygen.
    Team-O's Avatar
    Jul 2010
    Finland
    N96, N80 and N6630
    Well, well. This kind of messages we really need. Thank you b0z0k, thank you VERY much, I am very impressed.
    This is totally something else than messages "It does not work on my phone, help please" or "It works on my phone, thanks".
    This kind of messages will help the other members of the forum instantly. They find the information which is easy to understand, thoroughly studied and well justified. Rep ++ added.
    Regards,
    Team-O
    Aug 2010
    india
    5800 XpressMusic
    v50.0.005
    hi
    the serial keygen attached is for old ver 7
    can any one upoad for 10
    Administrator
    Raju's Avatar
    MobilePhoneTalk
    Galaxy S3
    Android 4.1
    Quote Originally Posted by nstl2k View Post
    hi
    use provided mlm then keygen will work
    Jul 2010
    Romania
    Nokia N79, Nokia N73
    I installed it according to the instructions and when I try to open it, it gives me an error message: "Disk error!". Please help me.
    PS: I have the Garmin 5.00.60 installed and works perfectly so in my opinion the memory card is good for the job, although it's an microSD-HC (8 GB).
    Best Regards,
    Mike
    Aug 2010
    uk
    nokia
    v 12.0
    thanks
    I have install it but when i launch it says no map loaded and i have already put gbr file into maps subfolder. Any help please
    Jul 2010
    london
    v51.0.006
    things i have found:
    sygic mobile 10 looks nice BUT it does not run as smooth as mobile 9 7.72 for example driving along say a straight road the map seems to run smoothly but every few seconds it jumps back a couple of meters like the gps is not picking bup the correct position. also the routing is far worse than version 9 it don't use the same routes as 9 did which were very good and when recalculation it always seems to wanna take you back on its own route, where in 9 it knew you wanted to go a different way and recalculated it in a much better way. also the maps in 9 were nicer especially in night mode and maps were the same version 7.80 which is also the latest in version 10. Also whats with the traffic? cant get no info from the internet or anything can i use it on a internet connection or i have to buy more hardware? which defeats the object of having it on my mobile.
    so for the moment i removed mobile 10 in favour of mobile 9 which suits me much better.
