Originally Posted by
b0z0k
Yeah.. It seems that the 8GB SD card is the culprit. I tried the 8GB card on my WinMo & it gave the same Device ID (it seems that the device ID are generated from the SD/ MicroSD card -- the phone does not change the Device ID). Because of the same non functional device ID, i can't register & i can't use it.
Tried the 2GB card from my WinMo to my Symbian phone & it works like a charm.
The device ID generated from that same 8GB card works with the keygen in My Sygic MM9 rel. 7.71. It is completely identical device ID but the keygen works in MM9. I think that somehow Sygic 10 use different method for activation key on SDHC card -- thus making the keygen non functional for SDHC cards.
So my conclusion is :
a) 1 & 2GB card works fine with the keygen on all OS (WinMo, Symbian, or Android)
b) i havent tried 4GB & 16 GB card, if it is SDHC perhaps it doesn't work too (need confirmation)
c) 8 GB card DONT work with keygen on all OS (WinMo, Symbian, or Android)
d) Device ID are unique to the SD / MicroSD card, so the OS & IMEI of the phone doesn't affect the device ID & the activation key from the keygen.
