can i flash the phone with this software 6300 nokia to make like new i have v07.21 i update with Nokia sofware update.. is work fine .. but can't create new connection configuration for internet acces is full 70 config inside .. required MT BOX for this
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.27.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
Searching for default location of ini...
Checking path: \Products\RM-217\
No ini files found...
Detected P-KEY: 90009699
Init usb communication...
Phone Type:
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm217__07.30.ppm_c
Phone Type:
Phone Type:
Searching for phone...Detected P-KEY: 90009699
Found
Error reading full info...
Found
Init usb flashing...
Error init usb flashing...
Reseting LifeTimer...
LifeTimer field not found...
Not supported!
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
Preparing for downgrade...
Failed to prepare for downgrade...
Searching for phone...Found
Reading SW version...Error reading rap ver!
Phone Type:
Phone Type:
Backing up CRT...
Reading IMEI...
Failed! Aborting!
