Hi all, just wondering if anybody might be able to help me with a problem I'm having with getting my new pc running Windows 7 (thanks Santa) connected to my wireless network at home.
Basically, it is a desktop pc with a wireless adapter. I installed the drivers for it then it searched for wireless networks and found mine straight away (Sky, WPA protected), so I clicked connect, I was prompted to put my security key in, which I did and I made sure it was correct, but when I tried to connect it says "windows was unable to connect to Sky****". My laptop, HTC DHD and PS3 have no problem connecting to the network.
I went into the router settings and disabled the security briefly and then it would connect to the network no problem. I then turned my DHD into a WiFi hotspot (WPA protected), the pc found it, I put the security key in and it connected no problem.
Im not sure where to go now so if any one could help that would be great.
Cheers, Craig
Edit: I have just switched to wep security and I can connect using that way and security disabled, I just can't connect using WPA....? What could be causing this?
