i done my swap and oc to 1.1ghz.. dunno y still at the intro screen thn jump back to home,,
thanks alot.
i had 1.21 and yesterday only with apk v1.22 file ,i updated to v1.22 and now only with .apk v1.23 file updated to v1.23 and it works perfectly.
How do I update this game when I had 1.22 installed and downloaded from here?
thanks alot.
exactly... mine stays 1.1 AS WELL, even after i delete game files and download them again from this installer of 1.23 version
For all those who get to the 3d selection screen then see corruption and crashes to phone menu:
Make sure you have the correct SD card download. If you don't have a Tegra chip and you have the folder 'cookedTegra' on your SD card you have the wrong download and it will crash when the game trieds to detect the chip. Download the other file for the non Tegra and you should be fine.
Have fun.
work on the desire???
works on desire hd rom on HD2 perfectly.![]()
when I check the version of my dundef in manage applications the version is 1.23. but in game it says 1.1. tried dl'ing it from their servers and it still says 1.1 . anyone that has 1.23 version in game? and if yes step by step instructions on how u did it. tnx!
