mlm for keygen
[PRODUCT:SMM10 Europe]
name=SMM10 Europe
tts=no sdk=no
truckAttr=no
premiumPOI=no
exPostals=yes
speedcam=SCDB:WORLD:2020.03
maps=TA:WORLD:2020.03
latest .mlm file for NAVTEQ:
name=SMM10 Europe
tts=no
sdk=no truckAttr=no
premiumPOI=no
exPostals=yes
maps=NT:WORLD:2020.03
1) If you already installed any version of
sygic you must uninstall it and then manually remove these dirs : MAPS-
DRIVE-RES generally located in e:\ (yours
memory card) NOT DOING THAT WILL
MAKE SYGIC NOT INSTALLING AND-OR NOT
WORKING RIGHT!
2) Simply run the .sis, apk file in your cell. 3) Copy these dirs Drive, Maps e Res in e:\
If Maps is not inside the .rar file simply
make it by yourself.
4) You can choose between TELEATLAS
(TA) and/or NAVTEQ (NT) maps. Best
solution is to have both of them. It must be for example e:\maps\GBR
where you unpack the GBR map. IMPORTANT -> the .mlm file must be in e: \maps! Simply copy the .mlm file from
the .rar file into e:\maps and no need to
edit it. Of course the maps are going as
always in a proper subdir. For example
GBR maps should go in e:\maps\GBR and
be sure to use a valid one!
5) Run Sygic at these point it will ask you
to activate the map(s). So get the keygen
and use it. Its pretty easy and clean.
Remember to select the option for sygic
